RA Rear Bumper + Greddy SE... will it work?
Postby ofey » Thu May 19, 2011 5:21 pm
No it will not work.
The RA bumper bar is a dual exhaust.
Your GReddy is a single tip exhaust.
scraverX
Postby scraverX » Thu May 19, 2011 5:22 pm
The regular SE won't work with the RA rear bar. It's built to exit in the factory position for NA cars which is quite different to the RA.
With an RA bar you either need an RA Rear muffler (as I have) or a custom twin tailpipe.
Further, any rear muffler sections built for an RA will need to be modified to fit a VRX as the middle pipe and connection are in different places.
Car & Home audio nut.
emmet-93
Postby emmet-93 » Thu May 19, 2011 5:24 pm
oh so it's going to be the biggest mission... don't think it's worth it :(
I might post again in the new members section asking for advice, give me a sec
Postby ofey » Thu May 19, 2011 6:12 pm
You could get it to work if you're desperate.
you'd need a 2nd matching tip
and
A very good exhaust welder who can cut and weld to match the tip on the other side.
driftnut((
Postby driftnut(( » Thu May 19, 2011 8:16 pm
just get the rear bar and a HKS legamax then get some one to alter it to fit the OEM pins, EASAAAAY
Users browsing this forum: Google [Bot] and 43 guests
