*CLOSED* Cree Q5 LED CCJ GB
For all ClubCJ Members.
Postby ofey » Wed May 18, 2011 10:34 am
Background
So there's been a demand for much brighter LED bulbs for our cars. Blakey has mentioned that Cree Q5s are pretty much the brightest we can get.
We've had problems though with the proposed supplier and now we've had to source for another.
Fitments
Sedan
Reverse = T20/7440 -- clearance is about 7 cm
Rear Signal (Amber)= T20/7440 -- clearance is about 7cm
Front Signal (Amber)= T20/7440
Sportback
Reverse = T15 --Clearance is about 7cm
Blakey wrote:Also note people getting the turn signals, these bulbs will most likly cause Hyper flashing (as they are only 5W bulbs) and may require a load resister of >20W capable at around 6 ohm i belive maybe even a 25W load resister at 6 ohm, just to keep the heat of the resistor down. (they are quite pricy)
Here are the new prices.
Both LED Bulbs come in Red, Yellow OR White.
T15:
1 - 50 = US$10 ea
>50 = US$8 ea
T20 (7440):
1 - 50 = US$10 ea
>50 = US$8 ea
Blakey wrote:id suggest spot for reverse, and astigmatism for indicators
as astigmatism is a more spread light rather then a directed focused light of the spot.
As you can appreciate, without knowing the size of the order, both blakey and myself cannot negotiate any further discount?
EOI:(if unstated assume white)
T15s:
White->
1. megatron 2X
T20s:
White->
NSW::
1. Hoges 2X
2. dannyboi 2X
3. Kyrus 2X
4. BrownSound 2X
QLD::
1. Blakey 4X
2. niro86 2X
3. megatron 10X
4. Flying Ace 2X
5. mechenggdude 2X
6. Tarquin 2X
VIC::
1. rthieu 2X
2. steve83 2X
3. meaty 2X
SA::
1. RyanMK 2X
Amber->
QLD::
1. Blakey 6X
2. niro86 4X
3. Flying Ace 4X
VIC::
1. meaty 2X
Postby ofey » Thu Jun 16, 2011 8:29 pm
Sorry I've had to restart this again.
New supplier. New Price.
Please EOI again... .
Meaty
Postby Meaty » Thu Jun 16, 2011 8:47 pm
EOI..... however i must protest that you make me spend WAY TO MUCH MONEY!!
Blakey
Postby Blakey » Thu Jun 16, 2011 9:17 pm
4 X white T20
6 X amber T20
dannyboi
Postby dannyboi » Thu Jun 16, 2011 10:01 pm
2 x T20 (white)
Kyrus
Postby Kyrus » Thu Jun 16, 2011 10:08 pm
2xt20white
燒
monty888
Postby monty888 » Thu Jun 16, 2011 10:23 pm
T20 - 4 yellow
T20 - 2 white
niro86
Postby niro86 » Thu Jun 16, 2011 10:44 pm
2 X white T20
4 X amber T20
Thanks Ofey
rayray
Postby rayray » Thu Jun 16, 2011 10:54 pm
2 x T20 white...thanks Irving!
BrownSound
Postby BrownSound » Thu Jun 16, 2011 11:35 pm
Ofey, please put me down for 2 x T20 White
Cheers :)
RyanMK
Postby RyanMK » Fri Jun 17, 2011 1:17 am
2 X White T20 please Ofey.
steve83
Postby steve83 » Fri Jun 17, 2011 11:57 am
2x T20 white please Irving, thanks.
megatron
Postby megatron » Fri Jun 17, 2011 12:09 pm
2 x T15 White
10 x T20 White
Flying Ace
Postby Flying Ace » Sat Jun 18, 2011 5:02 pm
2 x white T20 and 4 x amber T20, thanks!
