194 LED parking light bulbs
peternguyen
Postby peternguyen » Sun May 15, 2011 10:02 pm
I'm interested in purchasing some LED bulbs for the parking lights for better visibility. I've found that there are various different types of LED bulbs of the 194 type and I'm not sure what are the advantages and disadvantages. For example, on this page there are a number of different styles that seem to vary according to how much spread there is. Can anyone shed some light? Thanks.
Postby aspir3 » Sun May 15, 2011 10:08 pm
Postby Mitch » Sun May 15, 2011 10:23 pm
is this for the smaller light in our headlights is it which color is the legal way to go troy
Postby aspir3 » Sun May 15, 2011 10:28 pm
I have T10 white. They look nice next to my HID's. The old globes were yellow in comparison. I would show you a picture but they come up a slight blue colour in pictures.
Kyrus
Postby Kyrus » Sun May 15, 2011 10:31 pm
a random pare from my friend. looks awesome with jsut a tint of blue. or my friend suggested a brand called mtek.
燒
BrownSound
Postby BrownSound » Sun May 15, 2011 10:39 pm
Are these direct fits?
Kyrus
Postby Kyrus » Sun May 15, 2011 11:13 pm
yes they are, twist out the light, take out ur original parker, shove the new one in, twist the thing back in. thats it
燒
BrownSound
Postby BrownSound » Sun May 15, 2011 11:26 pm
Nice. I'll do this along with a new set of headlight lamps.
Do you guys think it would be weird to change the parkers and low beams only and not the high beams? Or should I just do them all?
BrownSound
Tarquin
Postby Tarquin » Sun May 15, 2011 11:28 pm
Yup - Plug and play.... The only catch can be it fitting into the actual hole in the corner of the headlight - E.g. That 6-LED Flat Top design linked from the 1st post may not fit into the slot.....
I have had a 5-LED Radial bulb in there before no problem - Like these >> Linky <<
The T10 194/168 is the size and style of the fitting.... The rest of the choices come down to how powerful you want the LED, the spread and design of the layout of the LED(s), and the colour.....
Any of the 'cool white' colours will be fine, and give A real white light (rather than the standard cream....)
Remember - Anything other than orange or white is ilegal in the front of your car....
- CCJ Premium Member #0015.
Tarq's Paintshop
Kyrus
Postby Kyrus » Sun May 15, 2011 11:36 pm
BrownSound wrote:Nice. I'll do this along with a new set of headlight lamps.
I have 6000K hid, my parkers are actually a brighter white than them. as for highbeam, it looked pretty chat when i had the stock bulb cos it was kinda like adding a yellow blob of light on top of a white blob of light. in the end i swapped them for philips blut visions 5000K, much whiter than stock but still look yellow compared to my hid. oh well.....
peternguyen
Postby peternguyen » Mon May 16, 2011 12:06 am
aspir3 wrote:I have these from Jaycar.
http://www.jaycar.com.au/productView.as ... BCATID=375
These look alright, do you know how long they will last?
rayray
Postby rayray » Mon May 16, 2011 12:43 am
LED's in general last for a very long time...would most likely last the life of your car
Blakey
Postby Blakey » Mon May 16, 2011 7:15 am
LED bulbs will produce next to no more light then your standard bulbs, next to all in production LED bulbs for cars, produce next to no more light then a standard halogen, there main differance, is colour and percived brightness,
there are a few bulbs out that that do produce more light then your standard halogen, but it makes no markitable differerence,
If you are after just a brighter looking bulb for safety and or just the look of LED's then go with LED, other wise dont bother they make next to no difference.
IF you are actualy after brightness i can link you a T10 bulb that is brighter then your stock headlights :p and yes they do fit in side the front parking light holes, (these bulbs are meant to be reverse lights, as T10/T15 is alot of cars reverse bulb size.
If you would like to know more i can put up a link, untill then, these are my secret.
megatron
Postby megatron » Mon May 16, 2011 12:00 pm
hi Blake im looking for a brighter reverse light can you help me?
