Front left headlight low beam isnt working?
BR14AN
Postby BR14AN » Tue May 03, 2011 2:10 pm
Hey guys,
So here is the back story.
I did have HIDs but have put back the stock bulbs (did this a couple weeks ago).
Today I noticed the front right headlight (lowbeam) isnt working?
I checked the fuse box in the engine bay under fuse 17, it is fine.
Any ideas?
Thanks.
just SC
Postby just SC » Tue May 03, 2011 2:12 pm
Have you checked the bulb of the low beam?
BR14AN
Postby BR14AN » Tue May 03, 2011 2:13 pm
I have checked the bulb, i put it in the other headlight socket and worked fine, so its not the bulb.
Sorry the title is wrong its the right side, not left.
BR14AN
Postby BR14AN » Tue May 03, 2011 2:16 pm
Is there another Headlight fuse under the dash?
just SC
Postby just SC » Tue May 03, 2011 2:24 pm
I dont think so. All my incidents to do with lights and fuses are from the central fuse box.
BR14AN
Postby BR14AN » Tue May 03, 2011 2:34 pm
I found the problem,
I was looking at fuses 16/17 when in actuality the fuses are 18/19.
Just a broken fuse, so its fixed now haha silly me!
just SC
Postby just SC » Tue May 03, 2011 2:49 pm
hahaha WIN!
BR14AN
Postby BR14AN » Tue May 03, 2011 4:55 pm
Hoges wrote:U just wanted post points so u started this thread didnt you.....
umm yeah lets go with that :D
eeko
Postby eeko » Sat May 21, 2011 11:07 pm
Hi guy's, I have the exact same problem occur to me today... Opened up the fuse box and changed both left and right fuses as well as swapping bulbs and my left one is still out.
Any other ideas on whats happened?
Thanks
Postby aspir3 » Sat May 21, 2011 11:13 pm
eeko wrote:Hi guy's, I have the exact same problem occur to me today... Opened up the fuse box and changed both left and right fuses as well as swapping bulbs and my left one is still out.
Thanks
You probably dis not fit some thing properly.
Use a volt meter and check for power and trace it back.
Return to “Electrical”
