I've been on this club awhile now and I've found that many new joinees find it hard to find answers to questions they have.
I've written a few things which I've been told are helpful.
So what I've decided to do is group these posts in one collated thread/post.
This will also help those who are asked, to find links. *saves us repeating*
I'll be adding to this as I go along.
If you know of any threads that I or someone else has written you think will help newbies, please PM me the link.
How do I improve the performance of my NA Lancer?
I want a RA Front Bumper. How do I do it?
I'm new and I have a question about my car.
- Joshuabeynon
- Zaphod
Mitsi wrote:Hey - Someone told me last night that we would increase the performance and fuel consumption simply by changing to a K&N filter, is this true? (2010 RA)
No.
If you install the RA snorkel (air intake pipe), install a freer-flowing exhaust system and then get a dyno tune you'll get a noticeable result; just installing a K&N will give you nice intake slurpy noises, but no performance boost...
(This assumes your current filter isn't dirty, if it is, just buy a new stock filter for a handful of $$$)
If you jump onto YouTube and check the MCM (Mighty Car Mods) channel, it'll explain it!
Megatron has access to well-priced RA snorkels if you want to go that route...
Tried mounting tow hooks: benen tow hook on the front bumper and password jdm tow hook for the rear. However, once i took the tow caps off the bumper, i realised the Canadian Lancer doesn't have any support for the toww hook to screw into. Its just a solid piece of metal from the crash beam beneath the bumpers - no holes / support for tow hook to latch. Maybe this is just a problem with Canadian spec lancers.
I know that just because I have a CVT, it is prohibited (my mitsubishi) to be towed from the rear, hence no tow support from the rear and prohibited to be towed or pulled straight on from the front, (so only tow support in front under the bumper/ chassis designed to lift front wheels off the ground) . But im puzzled on how to go about mounting the front and rear tows. Maybe drill into the crash beams, then weld a bolt onto it?(to screw tow hook) or maybe a self-tapping bolt/nut....or have a farbicate and weld a bracket ..... any ideas?
`Sign my guestbook y'all or leave comment: http://clubcj.net/garage.php?mode=view_ ... k&CID=1693
My Mod story so far: http://clubcj.net/garage.php?mode=view_vehicle&CID=1693
- nikil.de-lautour
- Lancer Learner
Re: I'm new and I have a question about my car.
Hello, im new to the group and would like some assistance please!
I have bought a 2009 Ralliart Lancer and am having some issues with it..
The idle is rough.. the RPM needle bounces around between 500rpm and 900rpm.. and the engine light has just come on due to this i think.. the only modification is a HKS panel filter that was already fitted when i bought the car.. Any ideas about this?
Also
The "sports" mode feels way too manic for some reason.. revs really high every gear and does not really drop back down through the gears quick enough when slowing down.. is this normal??
Also
Theres a crackling noise coming from underneath the car after i turn it off.. stays for about 5 minutes.. is this normal?? Seems strange that the noise hangs around for so long!!
Any assistance is much appreciated!!
Also
Also
To not give your best, is to sacrifice the gift
Users browsing this forum: No registered users and 145 guests
