EVOX front nose fix damaged RA nose?
axbci
Postby axbci » Wed Apr 20, 2011 9:11 pm
Hi all,
When I bought the RA, it came with a cracked nose (see photo's). Now I've just found an EVOX front nose, is this a simple swap? Will it fit the RA nose? If not, what are my options?
Thanks guys.
ax
tadz0rz
Postby tadz0rz » Wed Apr 20, 2011 9:27 pm
Unfortunatly not. You would be putting in a lot of work to make that fit and in the long run it wouldnt be worth it.
The evo has a more squared bottom section whereas the Ralliart is more rounded..
axbci
Postby axbci » Wed Apr 20, 2011 9:33 pm
Damn! Well if that's the case, might just see if I can it plastic welded then unless there's another option.
hasu12
Postby hasu12 » Wed Apr 20, 2011 9:36 pm
i got same it issue man ..nose just cone start to crack :O .. if u find solution i would like to know as well .. thx buddy
