Hi!
I have a oem projector lights which i install in my Lancer 09 RX.
All light plugs fit into the projector and all lights are working except for the high beam.
I was wondering does anyone have this problem when they install a oem projector headlights to a normal lancer model??
Thanks
OEM Projector High Beam not working
".FizyMo."
aspir3 wrote:Yes the centre lights come on when your steering gets to a certain point.
We have a switch to turn them off.
The low and high beam are in the projectors only on the outside.
ahaha ohh wow!!! always thought that lil light was a high beam..
thanks for the help guys
now the next question is, do u rekon i can get that working for my car? like where is the switch located in a aspire?
".FizyMo."
The switch is located just in front of the hand brake.
I believe it is the same type of switch as the stability control on the dash.
Lift up the panel around the hand brake and check if the wiring is there.
I would be surprised if it is plug and play in a RX.
The VRX probably have the wiring.
You would need some sensor for the steering as well I would imagine to make them work.
I find the lights quite annoying and not very useful actually.
The HID are an optional extra in the USA so maybe a dealer over there would be more helpful.
aspir3 wrote:The switch is located just in front of the hand brake.
Thanks champ..
jz went to my car and got a quik pic..
is this wat u are tlking abt
".FizyMo."
