Help me whit my new side skirts please
Surfero28
Postby Surfero28 » Wed Feb 16, 2011 4:40 am
Hi brothers
have if I can help
My car is a sportback to inform finish, come without side skirts and I have bought from a friend who has put in his car the evo kit
are painting the car for the full insurance
And the kid's workshop, I said you need a template to know where to make holes in the plate of the car.
Anyone know if this template? or I'll have to manufacture it myself? as would be the way to place and are perfect?
Thank you very much in advance, I put a couple of pictures for you to see how it has been after painting, is not finished yet.
srry my english its google traductor :)
Chubb
Postby Chubb » Wed Feb 16, 2011 8:53 am
I am not sure if any template does exist, maybe best to use some tape and spend some time getting them right by eye.
86MIM
Postby 86MIM » Wed Feb 16, 2011 9:03 am
Does the inside of the extension (side skirt) have drill markings? If so, possibly copy those to a sheet to copy to the car?
Spanish?
¿El interior de la extensión (lateral falda) tienen marcas de perforación? Si es así, posiblemente copiar esos a una hoja de copiar en el coche?
Or maybe Portuguese?
O interior da extensão (saia lateral) têm marcas de perfuração? Se assim for, eventualmente copiar os para uma folha para copiar para o carro?
That is as good as I can get Google to translate...
kii
tykkään kiiltävä, nopeasti ja se on saanut olla ähkyä.
_________________
ClubCJ Lifetime Member #86
Surfero28
Postby Surfero28 » Wed Feb 16, 2011 10:33 pm
thanks for the answers
The side skirt is each 10 staples that are stuck in 10 holes have to ask the car in front of the plate.
Then below are also 5 screws each.
And then takes double-layer tape all along the side skirt.
In the official manual mitsubishi explain assembly with a rubber washers are also dual-layer tape. Put them in each of the holes in the clamps press against the side skirt and car washers are stuck on the plate, marking the holes.
But do not find it anywhere these washers, I guess I'll have to grease staining or painting nails and doing the same procedure.
We make a paper template I see the truth very cumbersome.
Well now I will be reporting on how it goes
Greetings and thanks from Spain
