Front brake mount dimensions
All Brake Modifications.
El-Diablo
Postby El-Diablo » Fri Jan 07, 2011 6:50 pm
Does anyone know the front brake mount dimensions on a ralliart specifically the distance centre to centre on the mount and the bolt size.
whitenight
Postby whitenight » Fri Jan 07, 2011 7:00 pm
hey rob mounting holes centre to centre front is 129 mm and rear mounting holes centre to centre is 145mm. hope that helpes brembos wont fit
ToyLancer
Postby ToyLancer » Wed Jan 12, 2011 11:38 am
isn't it actually 130mm ? we measured this when looking for 380 brakes at wreckers. the 380 has 160mm centre to centre.
"Are you gunna bark all day little doggy, or are you gunna bite?"
-Mr. Blonde (Vic Vega), Reservoir Dogs
Return to “Brakes”
