FS - Ultra Racing Bar UR-LA4-442 Front Lower Bar
Rob_RA
Postby Rob_RA » Sat Jan 01, 2011 4:31 pm
ITEM: Ultra Racing Bar - UR-LA4-442 Front Lower Bar
ITEM CONDITION: Brand new, unused
REASON FOR SELLING: Not wanted anymore
PRICE AND PAYMENT CONDITIONS: $120 - Direct deposit or cash on pick up
SHIPPING AND POSTAL ARRANGEMENTS: Will post at buyers expense
EXTRA INFO: Brand new purchased through ofey in the last group buy.
CONTACT INFO: PM or 0407 697 288
rayray
Postby rayray » Sat Jan 01, 2011 4:41 pm
Hi Rob PM'ed you
exaltd
Postby exaltd » Sun Jan 02, 2011 1:22 am
Ray, THIS BAR WILL DEFINITELY MAKE A TONNE OF DIFFERENCE. Well worth investing into. A bit of a bitch to install though - bolts are really tight. I will need to spend an hour or so on it with a jack :P More info when we speak later :P
liam92
Postby liam92 » Sun Jan 02, 2011 10:21 am
This bar really does make the car feel alot tighter and sharper through the turns! The bolts are bloody tight though, I ended up extending a ratchet to a length of about 60cm and even then it was still a fight
Blakey
Postby Blakey » Sun Jan 02, 2011 10:28 am
exaltd wrote:Ray, THIS BAR WILL DEFINITELY MAKE A TONNE OF DIFFERENCE. Well worth investing into. A bit of a bitch to install though - bolts are really tight. I will need to spend an hour or so on it with a jack :P More info when we speak later :P
What? takes 10-20 min to install, just use a breaker bar, a ratchet, a jack, and some Stainless washers.(stock washers are just to small)
exaltd
Postby exaltd » Sun Jan 02, 2011 11:56 pm
Blake, I know the install should take that long. I was counting the jacking up time and some time if anything goes wrong (I work one step at a time when it comes to suspension and do that little bit EXTRA to make sure it is not just a backyard job). Plus I always do a safety inspection as well as trained.
Don't mind me, but I believe safety is key and taking longer times but getting it right and safe for the long term future can not be a bad thing.
Postby aspir3 » Sun Jan 02, 2011 11:59 pm
Make sure you torque up the bolts while the vehicle is on the ground with the full weight on the suspension.
exaltd
Postby exaltd » Mon Jan 03, 2011 12:05 am
Correct Troy. Backyarders may not know it, but it is important to torque it up with a torque wrench :) To do the job right first time.
Rob_RA
Postby Rob_RA » Wed Jan 12, 2011 7:03 pm
Sold = Mods please lock thread
