Hi,
I just bought a 2007 Lancer GLX, but it doesnt have the Trunk floor rubber plug, i've searched on internet but without luck, is there any website where i can get this? Thank you... is kinda anoying because bugs can get to the car because of that "Hole".
Sorry if this is not the right forum to ask.. i just couldnt figure out which one could be.
Thanks in advanced
white_devil
white_devil
white_devil
Here's the pic
Hi, this is the picture of what i'm talking about.
If its unclear please let me know.
Thank you
Thank you
white_devil
aspir3 wrote:Yes you an buy a rubber grommet that fits in the hole. Either a rubber supplier or Mitsubishi should have it as a spare part.
You could also put a spare tyre in and that should cover the hole.
I always worry when i see the plug missing as i think the car has had a water leak issue before.
Exactly, i'm having water leaks too, but i'll try with the rubber grommets, i'll try to find one!!
Thank you
white_devil wrote:aspir3 wrote:Yes you an buy a rubber grommet that fits in the hole. Either a rubber supplier or Mitsubishi should have it as a spare part.
Thank you
I would concentrate on fixing the water leak before plugging the hole. There is nothing worse for our car then water.
Often the seal at the top of the trunk has split and needs replacing or if it is okay then adjust the trunk to sit against the seal.
Parking you car on a forward slope often does not allow the water to run away as designed.
If you cant fix the water leak then maybe fit a rubber grommet with a short length of hose to let the water drain away.
- jolly_tas
If you put an S bend in it like in a toilet then you will have a drain plus water trap to stop the bugs getting into it!
Seriously tho, on a dry day, spray your car with a hose. Do one section at a time ie, 1) the boot lid, 2) the rear window, 3) the roof etc and check the boot after each section to see if there is water in it. If you see water then you have a good idea where to start looking for the exact location of the leak.
white_devil
Hoges wrote:Its not just moisture coming in through the plug hole is it?.
Actually, yes it is.. i think i missunderstood everything about the water leak (sorry guys, my english isnt too good) but im meaning water coming through the plug hole.
In my country (Dominican Republic) there's no Mitsubishi store, that's why i was asking about any website that can have it.
Sorry for the mistake, and thank you a lot guys
- jolly_tas
try these places online...
http://www.championparts.com.au/rubber- ... s-r_p.html
http://www.clarkrubber.com.au/rubber-se ... l#Grommets
measure the size you need then email them.
white_devil
Users browsing this forum: No registered users and 85 guests
