Evo x rear bumper/diffuser
Chimby
Postby Chimby » Sat Dec 25, 2010 12:44 am
Hey guys I was just wondering if an evo x rear diffuser fits on a normal cj lancer or do you need the whole rear bumper? If you need the whole rear bumper does it fit on with no problems or is work needed?
Cheers
Fully sik.
Postby ofey » Sat Dec 25, 2010 6:54 am
I suspect your question was because you saw them for sale on Lancer Shop?
But note the line they put in:
Fits: Mitsubishi Lancer Evolution X 08-09 (will ONLY fit MR models)
Let's try and look at this objectively then. Here's a picture of the Evo X rear in all its glory:
and this is a normal lancer:
Just note the section above the license plate. It's a thin line on the NA Lancer between the 2 rear reflectors.
Look at the Evo's rear bumper bar. It's quite a thick line of plastic between the reflectors. So no a genuine Evo X rear diffuser wlll not fit directly on. It wasn't made to. You do need a whole bumper bar.
JaCe
Postby JaCe » Sat Dec 25, 2010 7:57 am
Simplest solution is to get an aftermarket CJ Lancer Kit which is designed to look like the Evo bar.
... or go all out and do a full Evo conversion! :)
