Sorry if I posted this in the wrong forum I wasn't sure where this question is meant go...
Ok so this is probably a stupid question but the fan in my car seems to be emitting some weird random smells. It doesn’t happen when the air con is on or when I put the normal fan on. It’s just the normal air coming into the car. So far it’s been arse crack smell and now it’s migrated to bad pee smell... So my question is does anyone know what affects the vents that filter the air in? Maybe I just need to do some clean on an air filter or something? I have two air vent car fresheners in at the moment and one normal one sitting on the centre console. So I don’t understand where this smells are coming from!
I don’t think it’s the air outside coz i seems to be worse in the morning when I start the car. The air outside is fine doesn’t smell like what the car emits..
Any ideas anyone? It’s driving me nuts, especially in the last couple of days with the bad pee smell...smells like I visited some street corner that every man and his dog has peed on....
Help!
Weird random question :)
How old is your car and how many km's has it done? the reason I ask is it could be your cabin filter making the smell, all air entering the cabin comes via the cabin filter. To get to it you need to remove your glove box then pop the top of the filter housing you see in the dash. A new one of these will set you back about $25 from Repco or super cheap or $50ish from Mitsu.
^ What aspir3 said, should always turn your air conditioner off a couple of minutes before you stop if you arent planning on driving for more than an hour or so, especially night time. This happened to a mates car, and he used shoe deodoriser on the filter to get rid of the smell, and also washed it out. Worked for him, worth a shot or just buy a new filter.
Hmm, didn't know that. Learn something new everyday. Nice.
Well I've only had the car for about 2 weeks and have only used the air con about 6 times. So it's possible the old owner used to do that so I'm not really too sure about the condition of the filter.
Now that I know that now tho, I'll avoid doing that that.
I'll check out the filter on the weekend and assess the situation and see whether a new filter would be a better way to go....I might have to put up with the smell until then.
There are cans (single use spray) that you run with the air con in re-circulation for like a few minutes and it goes through your entire system killing bacterias, gems, etc...just like a flee bomb.
It's called vac or something like that. From memory they are under ten bucks from auitobarns.
Hug me please!
