Replacment clutch for Evo X?
mr_evo
Postby mr_evo » Wed Nov 24, 2010 1:44 pm
Hey everyone.
My clutch has just started slipping as of the other day, so I was just wondering if anyone else has needed to change their clutch on their Lancer or Evo. And what they have changed to and their reviews. I think I still have a little while till it will actually need to be changed. Keep in mind that I need something good for a lot of track work, ie; 80%+ of the time I will be driving my car it will be on track..
I have previously had a Exedy 5 puk brass button clutch, and I killed it within 5 months on my old 180SX :D I found it to be a good clutch, but probably not the best idea for my driving style.
€Cheers
Jase
Chuck
Postby Chuck » Fri Nov 26, 2010 1:34 pm
mr_evo
Postby mr_evo » Fri Nov 26, 2010 1:51 pm
wow glad you showed me that, never tried google before *crazy* :P
:D I'm back baby! :D
Chuck
Postby Chuck » Fri Nov 26, 2010 2:18 pm
I thought you'd be better off with Google considering most people around this joint consider putting vinyl on their roof a performance mod.
customundo
Postby customundo » Fri Nov 26, 2010 2:36 pm
Chuck wrote:http://tinyurl.com/33gb5ja
Argus Tuffed
Postby Argus Tuffed » Fri Nov 26, 2010 4:21 pm
lol @ Google, smartarse
Chuck
Postby Chuck » Tue Nov 30, 2010 1:05 pm
Mattigins wrote:
Chuck wrote:I thought you'd be better off with Google considering most people around this joint consider putting vinyl on their roof a performance mod.
Show me where someone has said that vinyl is a performance mod?
I'd go back and check the countless quotes I have quoted previously calling out morons like yourself, but my old account was deleted after being right about that guy who used to run the place stealing money...remember that? ;)
If you can un-delete that bad boy I'll happily show you, until then I'll guess you'll have to live in hope.
CA
Postby CA » Wed Dec 01, 2010 12:25 pm
How much power are you wanting to run?
I would go Daikin or Exedy stock clutch plate, with upgraded heat treated diaphragm and stronger pressure plate thats also heat treated.
I did the 5 puck brass button and its hard to drive.. great on track but it puts so much strain on the rest of your running gear.
If you dont launch it at every light then the clutch will be fine. I had tripple puck ceramic/brass button in my MR, and I went back to stock clutch.. and its lasted 7 years now. Coz i dont launch it..
mr_evo
Postby mr_evo » Thu Dec 02, 2010 8:24 pm
well rego is running out this month, so im gonna let it. got a price from NA Autosport Engineering for a Organic racing clutch that they make themselves. They said it wont feel good for normal street driving, but more than ample for upto 300awkw. which is fine for me :) and it is less than the price for an exedy clutch. I will keep you all posted.
PS. can we keep this thread on topic please, no jibber jabber about other crap.
Mods can delete all irrelevant posts.
Jase
Red EVOX
Postby Red EVOX » Thu Dec 02, 2010 8:45 pm
CA wrote:How much power are you wanting to run?
Yep im still running stock clutch in my X and its done just over 17000km and plenty of hard driving and netted a 11.66 1/4 sprint time.... yeah it does get a bit smelly if slipped whilst launching but at this stage i see no need to replace it because as us evo x manual owners know, that once the clutch is replaced with a "heavier" unit the clutch master cylinder will crap itself (as its made of plastic!)
mr_evo
Postby mr_evo » Thu Dec 02, 2010 8:52 pm
AMS have a soltuion for that problem, i think.
http://www.amsperformance.com/cart/AMS- ... -Ring.html
Red EVOX
Postby Red EVOX » Thu Dec 02, 2010 9:04 pm
That ring hasnt fixed things much at all. It holds the guts of the master cylinder together but then the end just blows out instead.
The fact of the matter is the plastic stock master cylinder just cant handle the added pedal pressure of a uprated pressure plate. Its a pity the metal unit from a evo 9 is a pain to modify and fit
mr_evo
Postby mr_evo » Fri Dec 03, 2010 3:52 pm
So why haven't any companies made a solution to that problem then?
Red EVOX
Postby Red EVOX » Sat Dec 04, 2010 8:39 am
SSP (south side performance) make a full replacement alloy master cylinder for the evo x but its had to undergo a few revision "models" due to small issues from a few that they have sold.
http://www.sspperformance.com/products/ ... ucts_id=29
When my clutch craps itself, i will most likely just replace it with a clutch that is similar to stock (pressure plate clamp loading that is) as i dont have any real issues with how it is and my car gets a good workout on the dyno and on the road/track
Jase: Maybe jump on the some of the USA evo forums like EVOX forums or evolutionm forums and check out what they have done in regards to master cylinder replacements/modifications.
