Radiator .VS. Condenser
just had a look and the radiator has been pushed in by the condenser and are leaning against each other would they have to be replaced if theyre like that?
- jolly_tas
check to see what is bent to cause them to move so much. also check the fins on the radiator... depending on the amount that are crumpled or if the actual water pipes inside the radiator have split then yes it will most likely have to be replaced or repaired. If you have any concerns then at least get the radiator pressure tested for leaks.
