Pod Filter
nathanbynature
Pod Filter
Postby nathanbynature » Fri Oct 22, 2010 12:26 pm
Hi there I put a pod filter on my 2008 ralliart and I am having problems with the idol amongst other things. Is it possible to fit this and have the car run normally? Has anyone else had this problem?
ClubspecCustomDesigns
Club Sponsor
Club Sponsor
Postby ClubspecCustomDesigns » Fri Oct 22, 2010 3:02 pm
Nathan i suggest you put it back to standard asap, you cannot use a pod filter with getting the car retuned.
Looking for that ultimate ride??
ClubSpec Custom Designs
www.facebook.com/ClubspecCustomDesigns
tjoz
Postby tjoz » Fri Oct 22, 2010 3:57 pm
What exactly did you do with putting on that pod filter? Have you placed it straight off the throttle body or placed it after the MAF sensor?
JaCe
Postby JaCe » Fri Oct 22, 2010 4:55 pm
PRESTON MOTORS RALLIART wrote:Nathan i suggest you put it back to standard asap, you cannot use a pod filter with getting the car retuned.
I thought a pod filter alone wouldn't be enough to cause any real issues unless it was poorly installed, or the MAF sensor was mucked around with (or not installed properly).
