Mudflap recommendations.
RyanMK
Postby RyanMK » Tue Oct 05, 2010 5:10 pm
I'm looking to get a set of mudflaps for my cj.
I've browsed through the forums a little and currently my options are:
1. Rallyarmour mudflaps.
-The basic mudflaps.
http://www.rallyarmor.com/store/lancer-basic-mud-flaps-p-249.html
-The UR mudflaps.
http://www.rallyarmor.com/store/mitsubishi-lancer-urethane-c-60_88_106.html
2. OEM mudflaps.
Picture can be seen here. Scroll down to the CJ lancer parts.
http://mitsubishi-motors.com.au/Genuine_Accessories_eBook/
3, DIY ones.
What I want to know is does anyone know of any other brands so I know my alternatives?
Or are they all about the same anyway?
WTR
Postby WTR » Tue Oct 05, 2010 5:52 pm
Do you have pics of 1. and 2. ?
Chubb
Postby Chubb » Tue Oct 05, 2010 6:06 pm
Personally I think the rallyarmor are the best due the fact they protrude out a lot further then any others. You will however still get the occasional stone chip on very loose surfaces but other then that since fitting the Rallyarmor my stone chips have reduced.
Here is a pic of Lethal_1's ride with the UR rallyarmor flaps which I also have
http://clubcj.net/garage.php?mode=view_ ... ge_id=1308
these will cost you around the $170 - 200 AUD amount however Rallyarmor do make a cheaper version for around half that figure that Drake89 has on his ride. Personally since seeing both my $200 flaps and Drake89's $100 I can see no difference.
RyanMK
Postby RyanMK » Tue Oct 05, 2010 6:42 pm
Added links to pictures in the 1st post.
@Chubb, where did you bought your Rallyarmors? Can I get them at Autobahn etc?
smithsy
Postby smithsy » Tue Oct 05, 2010 7:01 pm
If you've got stock width rims then OEM fronts are fine (and look subtle) with the side skirts and good value at ~$40-45.
Chubb
Postby Chubb » Tue Oct 05, 2010 7:02 pm
nah I had to buy direct from Rallyarmor in the states, www.rallyarmor.com
milobob
Postby milobob » Thu Jan 20, 2011 2:49 pm
Has anyone tried fitting the RalliArmor Mudflaps to a sportback?
