Hello All,
I recently bought an Isotta gear knob and was wondering if there was an adapter or something available to allow a tight fit on the shifter? I installed using the standard spacer that comes with the knob but it still spins slightly and is starting to annoy me.
Isotta Gear Knob
bit of a DIY back shed type fix mate but have you tried taping up the the shaft to make it bigger so the grub screws hold better. Or if it treads onto the stock shaft and is loose try some thread locking tape used on water pipes.
As you may have guess yes I am a farm boy
tape, wire and a damn big hammer fixes everything
hahaha, i gave it a shot last night but i gave up in the end lol. That bottle of loctite looked mighty tempting though
I'll give the shop another go and see if i can get a replacement adapter for the one that i broke off last night and see if something can be wedged in to tighten it a little bit more.
- Stalker
Chubb wrote:bit of a DIY back shed type fix mate but have you tried taping up the the shaft to make it bigger so the grub screws hold better. Or if it treads onto the stock shaft and is loose try some thread locking tape used on water pipes.
As you may have guess yes I am a farm boytape, wire and a damn big hammer fixes everything
MacGyver would be proud
