I just saw a picture of an Aspire and noticed it had projectors in the headlights.
Im assuming the lancer headlights are interchangable, just wanted to confirm before I go out and find a set.
Aspire Headlights in Activ
Once you have HIDs like the Aspire, you would need by ADR, a set of washers.
You can buy the body of the HID from an aspire but the Adaptive lighting system would have to be programmed into the ECU which you won't have.
It's not straightforward as just transplanting it in and plug and play... .
Vox sells HID Headlight Housings, no adaptive stuff to worry about. They make em for the RHD market, can also sell Philips bulbs and Matsushita ballasts (industry standard, so they told me).
I helped install a set, cost my friend $1080 from Malysia
you could also just use normal bulbs in them
"Are you gunna bark all day little doggy, or are you gunna bite?"
-Mr. Blonde (Vic Vega), Reservoir Dogs
