F.S. VRX front brakes-SOLD
Postby aspir3 » Fri Aug 27, 2010 10:52 pm
ITEM:Front brakes (2) complete. Discs, calipers, Pads and hoses
ITEM CONDITION: 4700km. Near new
REASON FOR SELLING: RA upgrade
PRICE AND PAYMENT CONDITIONS: $275 O.N.O
SHIPPING AND POSTAL ARRANGEMENTS: I will take to Melbourne for the National meet where they can be taken to NSW or Queensland or Purchaser to pay for courier
EXTRA INFO:
Calipers are painted red(High Temp.)
Discs are painted silver(High temp.)
Includes pads and hose
CONTACT INFO:PM, email or 0418107913
maleticj
Postby maleticj » Sat Aug 28, 2010 12:19 pm
hey what kind of paint did u use to paint the calipers ??
Postby aspir3 » Sat Aug 28, 2010 5:33 pm
high temperature 900deg.
bryzabone
Postby bryzabone » Sat Aug 28, 2010 8:17 pm
thats a bargain there Troy, if i hadn't blown 189$ on some low ride car-ramps, i'd be on these i reckon!
someone buy em, Quick!!
good luck with the sale! ;)
Postby aspir3 » Sun Aug 29, 2010 3:39 pm
I have added a picture to the original post taken today, as I have now taken them off.
They are ready to go. Pads are hardly worn. All I can say is the brakes are bedded in.
ToyLancer
Postby ToyLancer » Mon Aug 30, 2010 8:41 pm
question; do you need the brackets to cover the extra distance from the strut mount?
"Are you gunna bark all day little doggy, or are you gunna bite?"
-Mr. Blonde (Vic Vega), Reservoir Dogs
Mizta B
Postby Mizta B » Mon Aug 30, 2010 8:45 pm
Pheonix
The RA brakes bolt straight on as far as I know
I'll let you know when I fit mine soon
Merlinised....
Postby aspir3 » Mon Aug 30, 2010 9:46 pm
ToyLancer wrote:question; do you need the brackets to cover the extra distance from the strut mount?
My brakes will be a direct bolt on to an ES or VR.
The calipers just slip on over the axle. and the calipers just bolt on the same spot.
Eu-GenixX
Postby Eu-GenixX » Tue Aug 31, 2010 6:16 am
can i ask an idiots question? :S
what is the difference between these and the VR Brakes?
Blakey
Postby Blakey » Tue Aug 31, 2010 7:53 am
the only difference i belive is a slightly larger single piston. disks may be slightly thicker also.
the main difference is the rear brakes as they are actually larger dia rotors, To an ES and i think VR also
Postby aspir3 » Tue Aug 31, 2010 8:21 am
Eu-GenixX wrote:can i ask an idiots question? :S
They are about 25mm bigger in diameter, the discs.
Not sure about the calipers but I suspect like Blake said the calipers have a bigger piston.
They will have a bigger brake force then ES/VR brakes.
Postby aspir3 » Sun Sep 05, 2010 3:42 pm
bump
whitenight
Postby whitenight » Sun Sep 05, 2010 4:39 pm
hry troy how much did you buy the ra brakes for front and rear
Postby aspir3 » Sun Sep 05, 2010 4:44 pm
Ken I only bought the front brakes. I paid $350 plus delivery. I machined and slotted them and fitted new pads.
Postby aspir3 » Sun Sep 19, 2010 2:17 pm
BUMP!
I can not believe that some one with a ES or VR has not grabbed these already.
Look these are bigger then your brakes and travelled less then 5000km of light driving. I am very easy on my brakes.
If you have an ES or VR and especially travelled around 40-50,000km then you will be up for new pads and maybe machining. It would be a great time to fit these. Cheap and better then origin.
Remember every thing is there and they bolt straight on.
