boost guage
boost guage
Postby sleeper » Sat Aug 21, 2010 12:03 pm
anybody know the quality/accuracy of this one, it has the size,look and readings i want?
http://www.egauges.com/vdo_ind.asp?Type ... N=ATM-7608
comments, suggestions?
thank you.
Hecky
Postby Hecky » Sat Aug 21, 2010 12:31 pm
That's what I've got on my RA Steve. Works great, looks OEM etc...
Quality is very good, installtion looked simple enough (I didn't install it myself in the end), and readings seem accurate.
Only 'fault', if I can call it that, is that at night it's a bit too bright and it reflects off the windscreen. There is no 'brightness' adjustment. For pic check out my garage, I also put a 'switched off' pic here:
http://clubcj.net/viewtopic.php?t=4180&postdays=0&postorder=asc&start=960
Bottom line, for the price, they are definitely value for money.
HKS/AMS/GFB/MRT/K&N/DBA
Whiteline/Ultra-Racing/Rexpeed/Autometer/Yokohama Racing/Cusco
...and some other stuff which the fun police don't approve of... :)
Postby sleeper » Sat Aug 21, 2010 12:51 pm
yeah, looks oem hecky which is what i want, although u have the 20psi one, i want the 30.
did u buy it from here
http://www.rocketindustries.com.au
they want 123, plus 20 del., plus 42 for a black pod?
i wonder if u can hook it up to the dimmer on the standard guages??
Hecky
Postby Hecky » Sat Aug 21, 2010 1:24 pm
Got mine from fleabay....$150 delivered if I remember correctly....
Where you looking to mount it?
Hecky
Postby Hecky » Sat Aug 21, 2010 1:30 pm
$42 for the black pod??? That's crazy!!
Actually, I've got a black pod, never used it in the end. It is opened, but all the parts are in there. If you want it ($15? plus delivery) let me know...
Postby sleeper » Sat Aug 21, 2010 2:24 pm
hecky.
mounting it between the vent and the speedo/tacho bump on top of the dash similar to arutha.
what brand of black pod do u have?
and its 60mm?
autobahn just quoted me $165 complete instore with the autometer pod
billyboy
Postby billyboy » Sat Aug 21, 2010 3:00 pm
So is this gauge an electronic or mechanical type? Electronic are deemed more accurate.
Hecky wrote:Only 'fault', if I can call it that, is that at night it's a bit too bright and it reflects off the windscreen..
The one I've got has a dimmer function when I flick on my lights, but it does brighten up when boosting.
Postby sleeper » Sat Aug 21, 2010 4:22 pm
mechanical billyboy
Hecky
Postby Hecky » Sat Aug 21, 2010 4:57 pm
sleeper wrote:what brand of black pod do u have?
and its 60mm?
It's an Autometer pod, for 52mm gauge, product code #3204 I believe
Postby sleeper » Sat Aug 21, 2010 5:13 pm
ah, k, i need a 60mm, thanks anyway hecky :)
3204 is 60mm though.
Hecky
Postby Hecky » Sat Aug 21, 2010 6:00 pm
Ah, ok. Mine is definitely for a 52mm gauge.
Anyways, never mind. Good luck with it. And like I mentioned, the Autometer SportcompII are good, but a tad too bright...
Make sure you post some pics when it's all installed... :)
Return to “Interior”
