Ignition Problems with my Ralliart
myrali
Postby myrali » Mon Jul 19, 2010 10:30 am
I have a 2010 Lancer Ralliart and have noticed that if the Iphone is within 20cm of the key, the car has problems starting.
My brother has a blackberry and he has something similar happen also with his ralliart.
Spoke to Mitsubishi and they haven't heard about this happening.
Has anyone come across this before?
Blakey
Postby Blakey » Mon Jul 19, 2010 10:33 am
it would be a signal problem the key and the phone are proably transmitting around the same frequency, so they are interfering with each other.
myrali
Re: Ignition Problems with my Ralliart
Postby myrali » Mon Jul 19, 2010 10:40 am
Maybe mitsubishi can recode the keys to a different frequency
Blakey
Postby Blakey » Mon Jul 19, 2010 10:48 am
ii dunno, i think the frequency is determined by there wireless sender in the key, that transmits a code to tell the cars key ECU to unlock, allowstart, ect. i would presume the sender is the same in all cars.
the main problem with, that tho is the overlapping of signal. so the stronger/closer signal will take preferance over the other, at the same signal.
so i think the main thing you can do is either have your phone away from your key, or have the key closer then the phone to the keys ECU.
myrali
Postby myrali » Mon Jul 19, 2010 10:56 am
Thanks for that mate, i'll give it a try to see it helps
jaysewah
Postby jaysewah » Mon Jul 19, 2010 11:47 am
I have always had this problem with my RA. Similarly if I have my iphone and key in the same pocket the car wont unlock using the button or touch sensor etc etc.. I believe it is a standard common problem, my Dad has the same problem with the same type of key on his Lexus as well with his iPhone
Blakey
Postby Blakey » Mon Jul 19, 2010 11:51 am
sounds more like an Iphone Problem rather then the Keys fault lol
mikec
Postby mikec » Mon Jul 19, 2010 12:36 pm
i got the same problem with my vrx smart key
if i have my HTC in the same pocket as the key the touch unlock system on the car wont work.
shamrockshirts
Postby shamrockshirts » Mon Jul 19, 2010 2:28 pm
Interesting post... I do remember with the 08 RA model that if I had my mobile phone (and its not an Iphone) in the same pocket as my keys I had similar issues.
tomtom
Postby tomtom » Mon Jul 19, 2010 5:20 pm
this makes me happy to have a standard key :)
Users browsing this forum: Google [Bot] and 53 guests
