hi guys anyone put the plx dm-100obd2 gauge in a ralliart or evo,i know these gauges read out all parameters from the obd2 diagnostic port but is boost one of those parameters?
also want to buy the carbon fiber gauge pod that fits over the steering column, question is does this block the display behind it or can u see
over it
both items are on ebay
can anyone help?
	gauges in the ra
gauges in the ra
white ra+created flash tune 170.7kw@wheels
+boost pill+pedders ajustable coilovers and strut tops+k&n panel filter
PLUS
blue cj vrx +sun+sound+cvt+mmcs+baby seat+900kw
PLUS
Heaps of devices can scan/read your OBDII data and yes, Boost is one of them.
Everything from Garmin's latest satnav units to the iPhone bluetooth OBDII kits claim to be able to read the OBDII data.
I personally use a GReddy Informeter Touch in mine.
Which gauge pod you referring to dude? If it's the Rexpeed one being sold by Rota Aust on eBay (only one I know of which sits on the steering column) then yes it will block the lower part of your gauges, depends on your sitting position really. Actually the seller couldn't even confirm if the pod would fit the RA (pretty sure it does though). Are you looking at the single or twin pod?
									HKS/AMS/GFB/MRT/K&N/DBA
Whiteline/Ultra-Racing/Rexpeed/Autometer/Yokohama Racing/Cusco
...and some other stuff which the fun police don't approve of...
na just one if this gauge tells me all i need to know then its all i need,yeah its that one for  $130 on ebay it will fit all interior plastics are the same exept center console
PLUS
PLUS
yo daniel , you talking about this one ?
http://www.youtube.com/watch?v=A7GelX6po5g
those don't block meters as you'll be sitting at a higher angle so you should be able to see ur speedometer fine
Lancer Evolution 10MR
