WTB: STOCK CJ SHOCKS/STRUTS
MY08_CJ_LANCER
Postby MY08_CJ_LANCER » Wed Jun 02, 2010 10:31 pm
Hi I'm after a standard strut/shock for the front drivers side ( 2008 CJ ), clipped a gutter and bent on me.
OR if anyone could point me in the direction of a wrecker in Melb that might have one..
Cheers :)
Postby ofey » Wed Jun 02, 2010 10:46 pm
You could try Imlachs in Clayton.
else how much are you looking to pay for them? Please don't say as little as possible. Since you asked, you must know what they're worth.
Postby LZY_EYE » Wed Jun 02, 2010 10:49 pm
I would be checking that it is only the strut as well... Unlikely you would just damage the strut without causing other damage.
I would get it looked at and ensure there is not more damage before forking out money.
Might be better to claim on insurance.
Sickbunny
Postby Sickbunny » Thu Jun 03, 2010 12:04 am
Imlachs as Ofey suggested should have some.
they had quite a few lancers in stock when i got some interior bits.
it also could be a good chance to upgrade to some better shocks and lower the car if you are thinking of doing it in the future..
smithsy
Postby smithsy » Thu Jun 03, 2010 8:17 am
Also I assume it would be alike changing tyres, you change both of the fronts to the same struts of the same age, so as to not have any imbalances.
Also if you have a VRX their struts are different to those of an ES and VR (exact same dimensions but presumably the VRX struts have stiffer dampening).
I have a set of ES struts available within a week or so, but you'd be looking at needing to courier them from NSW. Although if you've bent the strut chances are you've bent a control arm, so I'd go to Pedders and get like a $28 14-point check or something like that. They should be able to tell you the extent of the damage.
MY08_CJ_LANCER
Postby MY08_CJ_LANCER » Sun Jun 06, 2010 7:17 pm
thanks to everyone who replied i got a strut couple of days ago from imlachs for $165, ive changed it now myself and the car drives straight as can be but my ASC light is still on.. saying service required.. is this something i need to get reset by a dealer or maybe faulty sensor or something else needs chaning? etc
Postby SAM-24A » Sun Jun 06, 2010 7:39 pm
I suspect it's a bent sensor mounting bracket causing a miss-alignment thus the ASC light.
Should be relatively cheap and easy to fix, so be aware of the dealers findings.
Cheers: Sam
Blakey
Postby Blakey » Sun Jun 06, 2010 10:38 pm
Im with sam here id say that its just a sensor problem take the wheel off and check its in place properly or if its damaged/bent bracket/sensor.
SIR-VRX
Postby SIR-VRX » Sun Jun 06, 2010 10:46 pm
I have 4 stock struts with springs from a VRX in my garage lol
I also have Evo X Eibach Springs if you're interested in those ;)
Blakey
Postby Blakey » Sun Jun 06, 2010 10:50 pm
SIR-VRX wrote:I have 4 stock struts with springs from a VRX in my garage lol
ok ill Ask WHY?
are they your struts?
SIR-VRX
Postby SIR-VRX » Sun Jun 06, 2010 10:57 pm
Yes, my original struts.
Blakey
Postby Blakey » Sun Jun 06, 2010 10:58 pm
SIR-VRX wrote:Yes, my original struts.
when did you get new struts?
SIR-VRX
Postby SIR-VRX » Sun Jun 06, 2010 11:00 pm
When I got lowered springs...
They are still stock VRX struts though.
Blakey
Postby Blakey » Sun Jun 06, 2010 11:04 pm
SIR-VRX wrote:When I got lowered springs...
oh ok so you just put newer VRX struts in.
im seeing if i can get some shorter front struts. so my springs dont fall out lol
SIR-VRX
Postby SIR-VRX » Sun Jun 06, 2010 11:05 pm
Did you zip tie like I suggested?
Return to “Buying & Trading”
Users browsing this forum: Google [Bot] and 10 guests
