Hi Hoges.
I got Hi-Tech's Cat-Back Muffler over 1 year ago, fitted with a Blue Diamond Oval Tip.
They do make one for our CJ Lancer. It's identical in shape & design (inlet /outlet) but its only 3/4 the physical size of the genuine OEM muffler. It fits and hangs in exactly the same place/position as the genuine muffler.
Hi-Tech own and operate thier own factory at Bathurst.
As soon as a new model car hits the market, they get the genuine muffler, copy and make it in a sports oriented version (straight through).
These mufflers are made of quality 316 Stainless Steel "Inside and Out"
Even the inside components which you cant see are made of 304/316 s/s unlike some other makes which skimp on internal component quality by using low grade 409 s/s.
The last car I had before my Lancer was a Nissan with a Hi-Tech Sport Muffler 15yrs old and the muffler was still good.
They also make a Twin Outlet Muffler (OEM copy) to fit-up directly to the Ralliart & EVO-X.
Quite at Idle with a very-slight burbble which comes on stronger over and above 3000-3500 rpm.
You will see mine on Sunday at the Botany meet.
Cheers: Sam
Hi-tech mufflers- exhaust option
