Heya,
I have plans, in future, to upgrade the OEM front rotors to slotted/vented.
question: can i then move the OEM front rotors to the rear, replacing stock solid rotors? that'd give me slotted/vented fronts, and vented rears. yummy!
is this possible without massive mod to the brake system?, fyi i'm running oem 16" alloys in an RX.
thoughts?
Rotor swap/upgrade?
Rotor swap/upgrade?
oh, i assumed i would take the whole assembly with it to the rears, pads, calipers etc. replace it all.
and on front new rotors, calipers/pads to suit new rotor as well...brackets if needed, but hopefully not
does that change things, or just a different colour of shyte?
haha, yes lotto permitting that would be a nice option.
the only prob with the vrx/ra upgrade to the fronts would mean i need 18" wheels to accomodate them, adding to expense
looks like this ones goin into my wishlist basket...
- spareparts
top up to an old thread, i found these:
http://www.dba.com.au/products/dba834sl
anyone with tech-savy-ness in brakes with thoughts on whether these can be fitted around the handbrake drum? I saw the evo's can fit series 7000 rotors on rears.....i wonder if these are the same deal
for 23$, worth a look for fun!!
There really is little point in putting slotted rotors on the rear.
They will most likely not fit as I don't believe DBA list parts for the current model Lancer, unless you have an RA or EVO.
The different grades in disc don't make the disc any bigger, they are different construction and have different methods for cooling etc.
Put a nice set of discs and pads in the front. If you can get your hands on some 2 pot RA calipers great, otherwise your only option is to go Ksport etc etc.
Hmmm, 2 pots would make all the difference...yummy....
question-is it true that you need to upgrade the master cylinder to accommodate the additional fluid flow/pressure?
eg. http://www.rpw.com.au/shop/index.php/co ... ory_id=176
