3M Di-Noc Carbon Roof + Parts (More Photos)
draevon
Postby draevon » Fri Apr 16, 2010 4:12 pm
So I spent all morning doing my carbon vinyl roof. Certainly not a job I ever want to do again, but pretty happy with the results. Also redid my interior, after originally doing it in Neffywrap. 3M Di-Noc is awesome stuff to work with though, and after using both, I'd definitely recommend it over Neffywrap if you can afford it. More details later ... I'm running late:
More photos added:
Alex.K
Postby Alex.K » Fri Apr 16, 2010 5:11 pm
WOW. Great work mate. You must be a perfectionist. ;)
even the steering wheel control panels. I wanna do that too
when you get back, please tell me how neffy wrap and di noc are different.
And how much they cost thanks :)
Lancer -> Accord Euro -> M3
Postby bd-850 » Fri Apr 16, 2010 5:49 pm
can we have some close ups of the roof??
Blakey
Postby Blakey » Fri Apr 16, 2010 7:13 pm
Alex.K wrote:WOW. Great work mate. You must be a perfectionist. ;)
neffywrap cloth material no sticky side Requires glue. cheaper.
Dinoc Carbon Vinyl a vinyl sticky side made my 3M Expensive.
1Sq Yard of NeffyWrap about $50
1Sq Yard of 3M Di Noc, >$100
Graham
Postby Graham » Fri Apr 16, 2010 9:55 pm
looks very nice! how did you get it into the curves so well?
Daily Driver: Yamaha R1
tadz0rz
Postby tadz0rz » Fri Apr 16, 2010 10:04 pm
We need bigger pics captain!!
Looks great draveon, you did a wicked job on the interior trims
JaCe
Postby JaCe » Fri Apr 16, 2010 10:06 pm
I'm very interested in doing this for my roof but was wondering what you thought of the process and how well it's staying on so far... also need to figure out how much 3m stuff I need to buy.
86MIM
Postby 86MIM » Sun Apr 18, 2010 1:55 pm
That looks awesome Tim!
Look forward to the roof close-ups :D
kii
tykkään kiiltävä, nopeasti ja se on saanut olla ähkyä.
_________________
ClubCJ Lifetime Member #86
draevon
Postby draevon » Sun Apr 18, 2010 8:52 pm
Thanks guys ... I'll answer a few questions:
The CJ roof is pretty much smack on 4x5 feet. Di-Noc rolls are manufactured 122cm (just over 4 feet) wide. You need a little more length to allow for some overhang. I used 160cm length for the roof and wouldn't want to use much less. I used the remaining 80cm I bought to do the interior. I wanted to do the rear armrests as well but didn't have enough vinyl left over so will buy a little more later on.
As far as the difference between Di-Noc and Neffy ... As Blake said, Neffy is a fabric and needs to be used with contact adhesive. Neffy wrap is pretty stretchy, but must be held in place while the glue dries which can be annoying and time consuming. Di-Noc is self adhesive. It's stiffer to start with, but when it's heated if goes ultra soft and can be stretched to a huge extent. Heating also makes it ultra sticky, and basically if you can stretch it and get it to stick initially, within about 4 seconds it'll be set there. It cools even stiffer then it starts and really locks in place (it can be heated and goes soft over and over again). Di-Noc feels a lot more durable, both in it's ability to stick more permanently, and it just seems like a more solid product.
I wouldn't try to Neffywrap the steering switches, because I don't think it would stick nearly as well, it's thicker so would interfere with the bottons, and also because i think it would wear poorly with me constantly rubbing my thumbs on it.
Cost-wise Di-Noc is definately more expensive, but I did my roof and majority of my interior for $230 ... that's still pretty affordable for a high quality product.
With regard to doing the roof, it took about 4 hours start to finish. I only used heat for the last 1/3 of the roof, and if I was doing it again, I'd probably avoid using heat, because by making it more stretchy, I can now see tiny waves in the carbon pattern. Not huge but enough for me to notice. The edges were a bit trial and error. I decided not to take the weather strips off after breaking the first clip I tried, but I think it looks fine the way it's done. Seems to be on nice and solid and looks pretty permanent.
Will take some more pics of the roof and the edges tomorrow ... let me know if I've missed any questions.
Hecky
Postby Hecky » Sun Apr 18, 2010 9:11 pm
Very nice....great work!
HKS/AMS/GFB/MRT/K&N/DBA
Whiteline/Ultra-Racing/Rexpeed/Autometer/Yokohama Racing/Cusco
...and some other stuff which the fun police don't approve of... :)
draevon
Postby draevon » Mon Apr 19, 2010 5:28 pm
Closeup photos added to first post.
Postby bd-850 » Mon Apr 19, 2010 5:34 pm
looks HOT, how did you do around the aerial?
draevon
Postby draevon » Mon Apr 19, 2010 5:35 pm
I took the aerial off, laid the vinyl, then refitted the aerial :)
Postby bd-850 » Mon Apr 19, 2010 5:39 pm
ahh cool
Postby aspir3 » Mon Apr 19, 2010 5:49 pm
Looks great.
Good job. Looks very professional.
It will be interesting how it is with the sun on it. It may help keep the cabin cooler?
Return to “ClubCJ Talk”
