Moisture inside headlights
Graham
Postby Graham » Tue Mar 23, 2010 5:38 pm
I've noticed some moisture inside my headlights since Installing angel eyes (obviously I've not sealed them up properly and it needs fixing :P) but was wondering how bad this is?
I understand that the bulb can blow if exposed to moisture and stuff, but how long would it take for it to blow? When I hit a kangaroo and it smashed open my headlight the HID blew after 5 minutes of direct exposure but the high beam was going strong until literally a month or so ago (dodgy auto repairer didn't replace the high beam when they replaced the headlight..)
I was just wondering because fixing my angel eyes would be "low priority" as taking out the headlights is a lot of work but I don't want to blow globes because that would be even worse safety-wise, not to mention I'd need to buy another set of HID's.
Any info is appreciated :D
Daily Driver: Yamaha R1
tadz0rz
Postby tadz0rz » Tue Mar 23, 2010 5:44 pm
Just pop your headlights back in the oven for a few minutes and secure the clips and glue back together properly...
Just make sure theres no moisture in there when you seal it back up ahah
Graham
Postby Graham » Tue Mar 23, 2010 7:34 pm
cheers, but my oven was too small in the first place so I couldn't use it.
I used a....a....a... hair dryer to melt all the glue.... :shock: :shock: :shock: :lol:
Ral1rt
Postby Ral1rt » Tue Mar 23, 2010 7:57 pm
Yeah, you have to be really careful with this. The Moisture can leave a rusty residue on the reflector. Seal it up asap. Another way to get the moisture out is to place a Towel over the headlight and leave your high beams on, But monitor it closely or you may melt your lens!
Owner: Matt Stewart
09 Ralliart tuned at MPC
13.22 @ 106mph Australia's 2nd fastest Ralliart. (Ill get you captain :-) )
Graham
Postby Graham » Tue Mar 23, 2010 9:27 pm
Thanks I'll try that, I may give it a go tomorrow, I'll buy some silicone or something from bunnings just incase theres any spots I missed.
Hopefuly the weather is good enough to let me take my car apart, otherwise I may have to wait until Saturday
