Has anyone fitted silicone hoses to their Evo (or Lancer?)
Found this on eBay for $70aud shipped: http://cgi.ebay.com.au/MITSUBISHI-LANCE ... 1564wt_939
Look quite nice and could spice up the engine bay. Any thoughts?
The hoses are different Blake.
The part where the radiator cap is in the Evo is slightly more towards the passenger side of the car. But I think we have the provision to move outrs over as the bracket on the radiator is ready to take it. Also the lower hose appears to be different, but I can't 100% confirm nor deny that yet.
Hence why I said Chubb and I are doing ground work already for it.
He has already had discussions with Gates about it, and I am assisting with my knowledge on the matter.
well, i was presuming they are the same, as mishimoto's radiator says it will fit both evo and normal lancer. as a direct bolt on. for both. so i presumed the pipes are the same seeing as i doubt they would change them,
but you may be right that they are slightly offset from the evo, it does seem feesable.
wheres a small pet pig when you need one. (cant spell the real name of it lol so i gave up)
Blakey wrote:its only the 2 pieces that are aftermarket, there is still piecs of his raggy cut up stock hoses lol
I think it is the whole hose you just put on, have a look.
http://www.killerglass.com/store/index. ... Path=65_76
probably last about 20mins before the join between the rubber and glass blew.
