Angel Eyes
Graham
Angel Eyes
Postby Graham » Sat Mar 06, 2010 5:06 pm
Finally got around to doing mine.
Fairly tired at the moment so I'll post up more info later, but here's the pics.
I just spent 30 minutes editing this post and it asks me to enter a reason and I lost everything i typed!!!!!!!!!!!!!!!!!!!!!!!! :evil: :evil: :evil:
RAAGGGEEEEE
EDIT:
slowly making a DIY, going from memory so I will proof read & may take pics at a later date.
Code: Select all
[c][b]How To: LED Angel Eyes for CJ Lancer[/b][/c]
Time required: 6 hours in total plus leaving the Angel Eyes to dry overnight.
Tools required:
 - Phillips Head screwdriver
 - Flathead screwdriver
 - Size 10 socket wrench
 - Drill with a small drillbit
 - Additional wire
 - Heat shrink tube & a lighter
 - Large Oven/Heat Gun/Hair Dryer
 - A strong adhesive, sikaflex recommended.
 - Patience, lots of it.
Risk Factor: 7/10
Difficulty Rating: 8.5/10
Basic rundown: You will be removing your front bumper and both headlights and taking them apart which can potentially permenantly damage your headlight. You will also be playing with some wires to connect the angel eyes to a current.
[c][b]Step 1 - Removing the bumper.[/c][/b]
Pop your hood and undo the 5+2 screws holding the piece of plastic above your radiator on and remove it.
Undo 5 more screws that you see beneath where the plastic was.
Under the front of your car you will see a piece of plastic connecting to the bumper, undo 5 more screws here.
On each side of the same piece of plastic you will see some more of those black "pop-out" plugs, remove 4+3 of these from the sides.
Undo the pop-out screws from the front wheel arches (just the ones connecting the front bumper)
There will also be one screw here that is hidden, it will be towards the top of the wheel arch, remove this from each side.
You may also need to remove the screws that hold your license plate on.
You will now be able to take the bumper off.
For each side you will need to gently tug (some force required) the sides and they will pop out.
Gently tug the bumper off from the front of the car as there are two more clips under the headlights that need to be popped out.
If you have fog lights now is the best time to disconnect the wire, you should see it quite clearly with the bumper half-off.
Your front bumper should now be removed!
[c][b]Step 2 - Removing the headlights. [/c][/b]
Daily Driver: Yamaha R1
Blakey
Postby Blakey » Sat Mar 06, 2010 5:15 pm
looks good you should of blacked out the inside when you had them open.
3mPty
Postby 3mPty » Wed Mar 17, 2010 9:18 pm
nice!!!!
Smokin'.....
Graham
Postby Graham » Wed Mar 17, 2010 9:21 pm
I think it's time I attempt to edit my post again, but I'm typing it in notepad first! lol
Bandit
Re: Angel Eyes
Postby Bandit » Thu Mar 18, 2010 8:05 am
Graham wrote: I just spent 30 minutes editing this post and it asks me to enter a reason and I lost everything i typed!!!!!!!!!!!!!!!!!!!!!!!! :evil: :evil: :evil:
RAAGGGEEEEE
Get Firefox.....
ClubCJ's first Sportback
Postby bd-850 » Thu Mar 18, 2010 8:13 am
looking good,
instead of black paint ti silver like the car :P
funnyfi
Postby funnyfi » Sat May 01, 2010 12:11 am
any pics at night?
kean
Postby kean » Fri Sep 10, 2010 11:04 pm
Where did you get those LED angel eyes? looks COOL!
ToyLancer
Postby ToyLancer » Sat Sep 11, 2010 2:19 am
yes, that is a great modification.
"Are you gunna bark all day little doggy, or are you gunna bite?"
-Mr. Blonde (Vic Vega), Reservoir Dogs
