Who runs RON98 in their VRX?
Since I bought the car from new I thought I would run RON98 fuel from day 1.
Is anyone else doing the same thing? If so what sort of mileage are you getting and do you think it makes much of a difference runnng the premium over the regular unleaded?
I have recently started to run my VRX on 98RON since i got it tweaked a little,it seems to run a little better and fuel economy is quite good.
Even before the recent induction and tuning mods i got it down to 6.1L/100Kms on a trip to Ballina,
I'm driving tp Coffs Harbour soon....I'll see how it goes then.
Merlinised....
Merlinised....
- Scott_VRX_Fan
- Lancer VR/GT
i generally either get bp premium or the shell equivalent.
i get between 650-700kms, mostly all freeway driveway, and thats pretty much a tank a week for me.
have used the lower quality stuff and found to get around 600kms a tank, so make of that what you will.
Mods Completed
Mods To Be Completed
Front Bumper Upgrade
Mods in Development
Mods in Development
maybe your car is a dud Aspir3... I get more range and better torque with few mods... might not save much for the benefits, but happier car... closer to optimal, than knocking....
I have proven this fact too many times to count, especially with bikes on a bike dyno... with zero mods just fuel change and 20mins for computer to correct.. higher torque figures...
how many RACQ tests do you have to read before its believed..
Our cars are sophisticated with Knock sensors and it knows if you runa high or low RON fuel... The Engine ECU actually has timing, ignition and fuel ratio maps for both High and Low Octane fuels...
Allows more timing etc for higher RON fuel
I've only ever had BP Ultimate in my car. Except during a shortage once I put $20 of Caltex Vortex98 to get me to a BP that had Ultimate in stock.
Hi Adrian,
you say:
If this is correct (I have no basis to doubt you) then more timing is definitley going to result in higher power outputs, albeit only slight depending on the amont of timming increase.
It would be interesting to know exactly how much the ECU alters the timing according to Fuel RON in use. Could you please post the ECU timing changes Adrian.
Anway our great politicians who do thier best to run this country (into the ground) re-announced last week that as of June/July 2011, Unleaded fuel will no longer be available.
Resulting in two fuel choices only: Premium Unleaded and E10. Fuel prices at my local last week showed unleaded @ $1.19 and Pemium @ $1.39 = 20c difference.
I wonder how the pricing structure will pan out next year when only two fuels will be on offer. Remember the Govt wants to promote E10, so if we apply the governments time and proven methods of extracting the Tax Payers Dollar, they will price increase Premium beyond affordabilty and thus allow the price of E10 to creep-up so as to appear competitive. Net Result for both the Govt (fuel tax) and the Fuel Companies (profit).
Cheers: Sam
you say:
Cheers: Sam
i have tried it before and noticed nothing.
a few weeks back they done this test on Fifth Gear, and each test they drained the tank, filled it with new fuel and reset the ECU and the most extra HP they got was about 5hp i think. but the main points they made was its not worth it, and if you do you HAVE to reset the ECU.
- jolly_tas
Have always run Caltex Premium (partner works for woolworths so get staff discount). On the odd occasion we have put a a splash of regular in the car we have noticed it doesn't run as smooth and seems to be less willing at lower rpm.
Sounds reasonable what Adrian said about the ecu changing maps depending on fuel type and adjusting timing etc... as that can explain the increased responsiveness at lower rpm.
That's just my two cents worth. Each to their own tho I suppose.
its not just our car that adjusts mapping to knock sensor output, its just about all (unless you have a car made in India or something)... Even my motorcycle from 2004 has it...
Cars (and bikes) have a plethora of sensors that contribute to the fuel mapping table. Some have, pre- and post- narrowband O2 sensors, knock sensors, absolute atm pressure sensors, airflow metering, air inlet temp, etc.. all this can marginally change the mapping...
There are gains, yes they are small. I get 60km extra on RON98 fuel, highway driving. Or, about 40km extra-urban. Also, my G TAC Pro recorded a faster overall 0-100km/h time, and increased torque, from 0.41G full-acceleration testing, to 0.43G on 98RON.
You dont have to reset ECU, they modify to suit fuel type after about 20mins of running, this is what my 2004 Moto Guzzi does. I am sure the Lancer is even more sophisticated... I have opened my ECU tabling on the Guzzi to read the mapping differences on both types of fuel, it is able to manifest 5% changes without reaching the prescribed limit of the cell. Anything higher would require a stand-alone fuel management computer, such as a PowerCommander... Cars work no differently.
Users browsing this forum: Google [Bot] and 32 guests
