Alarm Wiring Question
tadz0rz
Postby tadz0rz » Mon Jan 11, 2010 8:02 pm
Yoooo
Ive got an aftermarket alarm in my car and ever since ive got the alarm installed the boot release hasnt worked and ive had to press unlock on my alarm remote then press the boot release on my keys for the boot to open because if i just hit the boot release on the keys without unlocking the car, the alarm would go off...
On my alarms wiring diagram it basicly says
RED/WHITE ( - ) 200mA channel 2 Output - To Vechile Trunk Release Wire
If i run a wire from the alarm harness to the boot release wire would this stop me having to always unlock the car when i open the boot?
Thanks =)
SIR-VRX
Postby SIR-VRX » Mon Jan 11, 2010 8:06 pm
Is there a boot release button on your alarm remote?
That wire appears to be the output from that
R4LLI4RT
Postby R4LLI4RT » Mon Jan 11, 2010 8:08 pm
should be -- i hate after market alarms - they stuff up after 2 years or so.
3Inch Custom Cat Back Exhaust
Home Brand Alloy UICP
K&N Panel Filter Replacement
DBA Extreme Pads
Turbosmart Dual Port BOV
Tein S Tech Springs
tadz0rz
Postby tadz0rz » Mon Jan 11, 2010 8:09 pm
Theres no 'Boot Release' button on my remote, It just says AUX and if i combine the Lock and AUX key i get the second aux output etc...
SIR-VRX
Postby SIR-VRX » Mon Jan 11, 2010 8:50 pm
Post up a picture of the wiring diagram Tadz
tadz0rz
Postby tadz0rz » Mon Jan 11, 2010 8:54 pm
Ral1rt
Postby Ral1rt » Mon Jan 11, 2010 8:55 pm
Hey Tadz,
If its a 200ma Negative trigger you'll need to use a relay to trigger 12v+ to the boot release. Its quite simple actually. Unless you can find a diagram of the boot release cable colours you'll have to run a wire to the boot. Shouldn't be too hard to find the colours though. Find a negative trigger positive output relay diagram on google and hook it up that way. I can give you a hand if needed, I used to do this for a living but its been a while :-)
Owner: Matt Stewart
09 Ralliart tuned at MPC
13.22 @ 106mph Australia's 2nd fastest Ralliart. (Ill get you captain :-) )
SIR-VRX
Postby SIR-VRX » Mon Jan 11, 2010 9:08 pm
Looks like I have some competition for Chief Tech :lol:
Ral1rt
Postby Ral1rt » Mon Jan 11, 2010 9:11 pm
SIR-VRX wrote:Looks like I have some competition for Chief Tech :lol:
I dont think so my man :-) Your a wizz when it comes to mitsa's! I just know a little bit about alot, you know alot about....alot! hehe
Owner: Matt Stewart
Audio Express
Postby Audio Express » Sun May 02, 2010 10:30 am
since you are using a DEI alarm I would really suggest using a proper alarm on it. DEI make CAN bus alarms for these and they will control prettty much everything without having to find wires. for those that are buying the 5901 off ebay you will need an external CAN module to run the car. this is the easy way to do things.
Return to “Electrical”
