I know that this should probably be an easy no brainer but how do I remove the glove box? I want to get to the wiring behind it for some LED's.
I see there are four screws across the top of the glovebox but they're close to the airbag so didnt want to go playing round there just in case.
Thanks in advance
Glovebox removal.
Squeeze in the sides and it'll swing down further than normal, then on the left hand side you'll see a small cylinder, it's clipped onto a support. Basically grab the small cylinder and move it towards the driver side of the car and it'll pop off its support. Swing the box all the way down and you should be able to lift it out.
