spare key remote
- sicsid
spare key remote
Hi, i tried to use my spare key the other day and found that the remote doesnt work, the key still starts the car and everything but the remotes dead, has this happened to anyone else, i havent dropped the remote and havent used it since i got the car pretty much.
- Josh_Emerton
- Josh_Emerton
- Tin_Pusher
- Lancer ES/EX
Just to help out here, both to clarify what *should* be happening and also satisfy myself that in the event my main smartkey goes flat .......
Mine is a MY10 bought 2 months ago. I just took my spare smartkey to the vehicle, and it both opened OK and started - and no need to remove the key itself.
In short, it behaved exactly the same as the main smartkey.
- Josh_Emerton
- Josh_Emerton
In most remote central locking cars with engine immobilizers, the remote central locking is programmed differently from the immobilizer. There is a chip in the key which activates when you stick it into the ignition to 'mobilize' the car. So the reason why you were able to start the car was because it is seperate from the remote central locking, so the issue lies in the remote either lost the programming or dead battery. Either way it should be fixed free under warranty new battery wont work
clem wrote:In most remote central locking cars with engine immobilizers, the remote central locking is programmed differently from the immobilizer. There is a chip in the key which activates when you stick it into the ignition to 'mobilize' the car. So the reason why you were able to start the car was because it is seperate from the remote central locking, so the issue lies in the remote either lost the programming or dead battery. Either way it should be fixed free under warranty new battery wont work
The 1 computer controls it all in the CJ
WCM (Wireless Control Module) for regular models
KOS (Keyless Operation System) for Smart Key Models
Once a signal is received to unlock/lock it sends the message to the ETACS ECU to perform that function.
And when the key/knob is turned to START it tells the Engine ECU if it allowed to start.
All via Encrypted messages over the CAN-BUS. So very hard to bypass. So if the car wanted to get stolen, they'd have to steal the key!
