Painting the caliper?
All Brake Modifications.
Micoa
Postby Micoa » Tue Dec 29, 2009 9:49 pm
hey guys,
i just bought a can of RED caliper spray paint from the brand MOTOSPRAY
and i was wondering if it was necessary to remove the whole caliper off or would it be easier to spray while still attached to the car?
i would like some advice as i'm a complete noob
hehe :P
Postby The X » Tue Dec 29, 2009 9:54 pm
Make sure you clean the calipers thoroughly, free of any brake dust and/or brake fluid.
Best would be to remove the caliper (if you know how to do that) and then you'd need to bleed the fluid to ensure you have brakes afterwards.
Else you can using masking tape (lots of it) to cover the disc and clips and spray paint or you can spray the paint into a small container and apply with a small art brush. I think Graham on these forums did the latter. Ensure you also cover your driveway/floor to avoid paint drips. :)
Postby aspir3 » Tue Dec 29, 2009 9:56 pm
If you are not good with cars do not remove the calipers as they will need bleeding afterwards.
Someone has painted them with a brush and they came up really good in the photos's. He sprayed the paint into the cup, first , then brushed.
tadz0rz
Postby tadz0rz » Tue Dec 29, 2009 9:57 pm
What some members have actually done when painting their calipers is just spraying the paint into a cup or something and brushing it on.
Once i get round to painting my calipers thats what im going to do. Ill make a video when i do it aswell, like always 8)
Edit: DARN YOU ASPIR3!!! Beat me to it!! :P
Postby The X » Tue Dec 29, 2009 9:57 pm
Here's Graham's attempt like I mentioned.http://clubcj.net/viewtopic.php?p=76282#76282
Postby The X » Tue Dec 29, 2009 9:59 pm
tadz0rz wrote:Edit: DARN YOU ASPIR3!!! Beat me to it!! :P
Actually I beat ya both. :P
Micoa
Postby Micoa » Tue Dec 29, 2009 10:02 pm
seems like an easier option to spray into a cup than to remove it ,
what would i use to clean the brakes before i paint over it, do i need some special spray? or can i use something from home...
and what part should i not paint, because i see some reflective metal on my brakes, is it safe to paint that?
Postby aspir3 » Tue Dec 29, 2009 10:04 pm
me first.
Most automotive shops have break cleaner.
The easiest way is to pm me and organise to meet me and I can show how and what to use, as your brakes are the most important thing on your car. you must not get moisture or greese on the pads. Best to remove the pads and take the calipers awar from discs and support caliper as it will still be connected to hose.
tadz0rz
Postby tadz0rz » Tue Dec 29, 2009 10:06 pm
I was looking for the how to, not grahams thread :cry:
I think tomorrow is going to be a pretty boring day for me, might paint the calipers if ive got enough cash left in my wallet lol.
Ill be sure to make a video on how to do it aswell
Postby The X » Tue Dec 29, 2009 10:11 pm
Micoa wrote:seems like an easier option to spray into a cup than to remove it ,
Just buy yourself some brake caliper cleaner from your local Repco store. I bought some Motortech brand caliper cleaner y'day for $5.09. It's a can of 400g. Use a scourer sponge and wash down and let dry.
Painting my calipers is on my to do list (read, in the new year). I've bought some VHT red and also some VHT gloss to get the nice glossy look.
Postby aspir3 » Tue Dec 29, 2009 10:19 pm
If you paint your calipers, you should paint the edge of your dics at the same time.
Micoa
Postby Micoa » Tue Dec 29, 2009 10:20 pm
paint the edge? what do you mean by that? :shock:
Postby The X » Tue Dec 29, 2009 10:21 pm
aspir3 wrote:If you paint your calipers, you should paint the edge of your dics at the same time.
Sounds a bit ghey. Why won't you do yours? ;-) i think should put swirly pinstripes on your discs. :P
Seriously tho, what you mean the edge? Rim or ???
Postby aspir3 » Tue Dec 29, 2009 10:49 pm
On the edge of the disc! The disc's rust, due to type of cast steel they are made from. The faces are constantly cleaned by the pads giving a clean steel finish, but the edges or outside of the discs do not get touched by the pads.
I have not had a look at my Lancer as I have done enough Km's to rotate the tyres, but painting the disc's with a high temperature black paint stops them rusting. If you go to the effort to paint your calipers red, you may as well paint the disc's black to finish the job! Any paint on the disc faces will be removed on the first braking.
tryg
Postby tryg » Tue Dec 29, 2009 10:55 pm
the chances of a rotor failing due to surface rust = zero...
seems like a lot of work for asthetics...
IMHO not necessary..
You should use brake cleaner, or a solvent based cleaner.. or even just good dish washing detergent followed by isopropol alcohol wipe...
painting by brush will leave it less glossy.. so its up to you what finish you are happy to have.
Good luck
Return to “Brakes”
