Iridium IX BKR5EIX-11
Anyone using these?
The plugs you have standard are better
NGK Laser Iridium are the standard plugs, go look
Laser Iridium > Iridium IX
Part number is FR6EI-11
I just replaced mine the other day. Rated to 100,000 but changed at 54,000 because I had burn marks up the upper insulator. nothing to worry over really,but I just didn't like it and for the price I paid for the plugs it's no big deal.
- Josh_Emerton
If budget permits, the HKS Superfire suited to our cars.
Usually I would recommend the NGK Iridium IX but since our car came standard with the NGK Laser Iridium, choose them like I installed (and had standard)
NGK Laser Iridium FR6EI-11
They are good for 100,000kms though. Iridium IX good for 60,000
Well if money isn't an object then better than the HKS are NGK DFE Laser Iridium...
I just went with one rating higher (hotter) because there is a fair amount of fouling on my plugs...
I may not keep these, will check after my run to your house tomorrow Adrian..
I would like to try the DFE Iriidum plugs.. if they ever bother to import them.
I looked at my brand new ones and I could see why they got the burn marks... There is a white powder around the base of the ceramic insulator... It appears that burns with the heat, sealing the insulator to the metal? Just a guess.
But for $7.69 each I wasn't going to not replace them while i had them out
- The X
I'm sure you could.SIR-VRX wrote:Repco Staff Price
Would get it for everybody if I could!! Trust me!
