Side Skirts..
bye2u
Side Skirts..
Postby bye2u » Fri Dec 25, 2009 11:20 am
Does anyone know if the side skirts on the vrx/ra are the same length as the evo x's?? :D
tryg
Postby tryg » Fri Dec 25, 2009 11:44 am
I have wondered this too! There are some mad kits out there in CF for EVO Xs....
bye2u
Postby bye2u » Sat Dec 26, 2009 1:50 am
yep that's what im after as well.. a cf side skirt extension :)
tryg
Postby tryg » Sat Dec 26, 2009 11:18 am
oh i see... I was thinking of just tasty CF whole skirts.. but alas.. too pricey!
bye2u
Postby bye2u » Sat Dec 26, 2009 11:39 am
the sideskirts for the evo wouldn't match our cars anyway imo.. since the evo is widebody it wouldnt flow with the lines with our car to the front and rear bumpers..
im after side skirt extensions that just for under the skirt..
tryg
Postby tryg » Sat Dec 26, 2009 2:30 pm
But that looks so sweeeeet !!!!
Graham
Postby Graham » Sat Dec 26, 2009 4:11 pm
I want that too :O
I wonder if it will fit the stock VR+ side skirts
Daily Driver: Yamaha R1
tjoz
Postby tjoz » Sat Dec 26, 2009 4:49 pm
These could possibly fit non-turbo Lancer sideskirts. They bolt under the sideskirts (drill them in), no actual mounts for them so they can be positioned wherever (roof even if your up for it). The only one they wont be so easy to fit are ES without sideskirts.
I dont see why these wouldnt fit, they are only attached to the bottom of the sideskirt. They dont hook up to the sides or anything. You will need to drill them in. Pretty sure they dont even come pre-drilled.
Its like the front splitters you can get, huge piece of carbon fiber that you mount up yourself.
tryg
Postby tryg » Sat Dec 26, 2009 5:33 pm
The one at the front is called a ground effect splitter...
bye2u
Postby bye2u » Sat Dec 26, 2009 8:08 pm
tjoz wrote:These could possibly fit non-turbo Lancer sideskirts. They bolt under the sideskirts (drill them in), no actual mounts for them so they can be positioned wherever (roof even if your up for it). The only one they wont be so easy to fit are ES without sideskirts.
its best to ask first.. as ive seen a few that have pre-drilled mounts..
JaCe
Postby JaCe » Sat Dec 26, 2009 8:46 pm
They really do look awesome. Maybe I should invest in some!
PYLee
Postby PYLee » Sat Dec 26, 2009 8:53 pm
do itttttt
Lancer Evolution 10MR
tryg
Postby tryg » Sat Dec 26, 2009 8:54 pm
They are still quite expensive though (for flat CF)....
SIR-VRX
Postby SIR-VRX » Sat Dec 26, 2009 8:58 pm
The length of the skirts is the same!
But the Evo skirts protrude out further at each end (to match up to the widebody)
bye2u
Postby bye2u » Sat Dec 26, 2009 8:59 pm
gotta pay to play :D
