Query about the inside of the roof trim
cjsig
Postby cjsig » Sun Dec 13, 2009 4:04 pm
Typically those who has the ES variant of CJ model.
Seeing that the higher trim models has the extra interior lighting towards the front windscreen, i was wondering, is the wiring loom there within the ES model?
So has anyone ever removed the interior roof trim? I was wondering if there are the wiring loom there.
let me know if this has been asked before xP
cheers!
thats the light unit that im talking about. i was just wondering if the cables are there.
scraverX
Postby scraverX » Sun Dec 13, 2009 5:47 pm
AH the map lights. I would assume the wiring is there as the wiring is in place for things like the steering wheel audio & paddle shift.
I am just making an assumption though.
Car & Home audio nut.
tryg
Postby tryg » Sun Dec 13, 2009 6:19 pm
Good question, well asked...
If you get the lining off, don't forget to Dynamat in there!
I would also love the map lights, if the mounts and wiring were evident.
exaltd
Postby exaltd » Mon Dec 14, 2009 12:48 am
I think they don't exist on the ES.
At a Melbounre meet, I asked the same question. Ofey and Aspired did mention that you would have to wire it all yourself, as they did not find any wiring in that area at all.
I could be wrong though. This is what I remember of what they told me.
I'm annoyed that we don't get these map lights, they are a very useful light to have.
-EXALTD-
Postby ofey » Mon Dec 14, 2009 6:16 am
try taking it off? you only need to remove the a-pillars to get the front bit off
Graham
Postby Graham » Mon Dec 14, 2009 6:54 am
As far as I'm aware the ES doesn't have this wiring bit but my VR does.
There might be a wiring loom but I'm not too sure, as Ofey said, try taking it off and checking :P
Daily Driver: Yamaha R1
Postby LZY_EYE » Mon Dec 14, 2009 9:15 am
It wouldn't be hard to run some wire from the dome light anyways, even if the wiring is not there. If I do my lining I will probably install the maplights....
Return to “Interior”
