Adding Automatic Down for all windows?
- tadz0rz
Yo!
Just curious...
If we are able to get the parts of PMR, would it be possible to hook up the automatic wind down for all the windows? Insted of just the drivers?
I dunno if it runs through the ECU or anything like that or if it just runs on a relay, but would it technicly be possible or would it be more trouble than its worth? Understandably, more wiring would be needed...but is it possible?
Just curious...
I know
Even my work van has auto up/down on all the switches, even on the passenger side switch.
It is a Mercedes-Benz though hahaha
if you want it all you need it the switching modules that do it. buy a few insert into window wiring. then you will have it. go to a merc wreckers and rip some out of an wrecked ones dash?/door? where every they keep there modules.
also jaycar sells a module/kit that you can just put in the wiring to do it for down i belive.
