bought an instrument cluster from a 18 ASX and when plugging it in a turning car on (both on and engine running) throws trans overheating, trans service and power steering faulty. the code that i see is U1415 and is there any way to remove this code? I know its an active code so i dont think there is.
would changing the VIN fix the issue? or is something harder like a canbus related issue
u1415 code when replacing instrument cluster
- adamhumphrey
Re: u1415 code when replacing instrument cluster
Maybe contact the facebook page MMCodingwriter and ask the question there, the users on there are really switched on with ETACs coding and the software can change the vin code within the odometer.
Facebook Link https://www.facebook.com/groups/2273408659369453
Forum Link https://forum.kolyandex.su/index.php?sid=e271d485c0ee81fc636e321068778ddc
The error is pointing to Coding not completed/data fail, maybe due to it being from an asx thats newer it may have things enabled in the etacs and odo which it can't see now. But Im a bit of a noob in this stuff. I have played around with some settings but not much else
MY11 Evo X MR (2011-Current)
MY20 Asx GSR (2023-Current)
