Headlight adjustment
lxlancer2014
Postby lxlancer2014 » Mon May 08, 2023 9:56 pm
When you adjust the low beam elevation, does that also adjust where the high beam is pointing, or is there a second adjustment for that somewhere else on the headlight?
I installed some new led bulbs and they basically project at the same height as the high beam, making the high beam redundant. I just want to raise the high beams independently of the low beams now.
2014 Lancer LX 2.0 CVT
>Stock as a rock
Re: Headlight adjustment
Postby aspir3 » Tue May 09, 2023 8:39 pm
They are adjusted together.
I don’t think the Lancer headlights are suitable for led. It’s important the light element is in the correct position as the headlights reflect the light forward. Using different globes omits the lights in a different position causing the light not be be focused correctly. This causes poor light for the driver and REALLY annoying and dangerous blinding to other drivers
adamhumphrey
Postby adamhumphrey » Tue May 09, 2023 9:06 pm
aspir3 wrote:They are adjusted together.
Correct led are more suited for Projector style headlights.
MY11 Evo X MR (2011-Current)
MY20 Asx GSR (2023-Current)
Postby lancerdarryl » Thu May 11, 2023 8:46 am
You you are going to get adjustment correct with LEDs Just but some quality brand halogen globes. Yhis is the best you will do
Postby lancerdarryl » Thu May 11, 2023 9:01 am
