07 to 09 lancer trims with security alarms
Do all older lancer models and trims not come with Alarm systems? I see the fuse is plugged in the fuse box yet it seems like I'm not able to activate the alarm. So does this model year have the built in alarm system? or do they only come with the engine immobiliser?
- lancerdarryl
Re: 07 to 09 lancer trims with security alarms
I think they only had an immobiliser
lancerdarryl wrote:I think they only had an immobiliser
Why only the immobiliser and not have the security system? and why have the fuse connected in the fuse box yet it doesn't do anything
- lancerdarryl
That my friend I cannot answer. The alarm was only fitted to Evo,Ralliart and Aspires and possible Vrx however I’m not sure about the Vrx
lancerdarryl wrote:That my friend I cannot answer. The alarm was only fitted to Evo,Ralliart and Aspires and possible Vrx however I’m not sure about the Vrx
Oh okay, would it be possible to install an aftermarket system and have it still synced to the keyfobs?
- adamhumphrey
I think it would have to be a canbus alarm. It would make sense to do it that way to avoid extra remotes and it would stop the factory immobiliser getting annoyed with the extra stuff. This wouldnt be a diy install. I used to fit car alarms for a company for many years. They are very compicated.
Mongoose Map77
https://www.mongoose.com.au/map77-canbus-factory-security-upgrade
Viper 3903TR
https://www.vipersecurity.com.au/products/factory-upgrades/directed-3903t-canbus-oem-upgrade-security-system-nissan-ford-toyota
Cyclops 695Kit
https://www.streetsoundvision.com.au/cyclops-695kit-canbus-upgrade-alarm
The other option is to find out what bits are required for the Oem alarm and fit those and enable using ETACs software. Lots of People do this on Peugeot cars. They have similar software and in lots of cases where the same in some cars as the Mitsubishi cars. This is how they originally made stuff to customise the Etacs.
Part catalog for Evo X
https://catalogs.ssg.asia/mitsubishi/?lang=en#bWFya2V0PT1qYXBhbnx8c3Q9PTUwfHxzdHM9PXsiMTAiOiJSZWdpb24iLCIyMCI6IkphcGFuIiwiMzAiOiJHQUxBTlQgRk9SVElTXC9MQU5DRVIgRVZPTFVUSU9OIiwiNDAiOiJDWjRBIiwiNTAiOiJTTlhGWiJ9fHxDYXRhbG9nTm89PUEwMTZZMTA1QXx8Q2F0U3RhcnREYXRlPT0yMDA3MDgxfHxDYXRFbmREYXRlPT0yMDE2MDEzfHxNb2RlbD09Q1o0QXx8Y2M9PVNOWEZa
Part calalog for Lancer
https://catalogs.ssg.asia/mitsubishi/?lang=en#bWFya2V0PT1qYXBhbnx8c3Q9PTUwfHxzdHM9PXsiMTAiOiJSZWdpb24iLCIyMCI6IkphcGFuIiwiMzAiOiJHQUxBTlQgRk9SVElTXC9MQU5DRVIgRVZPTFVUSU9OIiwiNDAiOiJDWTRBIiwiNTAiOiJXaXRob3V0IHBhcmFtZXRlcnMifXx8Q2F0YWxvZ05vPT1BMDE2WTEwNUF8fENhdFN0YXJ0RGF0ZT09MjAwNzA4MXx8Q2F0RW5kRGF0ZT09MjAxNjAxM3x8TW9kZWw9PUNZNEF8fGNjPT0w
Good luck I'll try to help if I can
Mongoose Map77
Viper 3903TR
Cyclops 695Kit
MY11 Evo X MR (2011-Current)
MY20 Asx GSR (2023-Current)
adamhumphrey wrote:I think it would have to be a canbus alarm. It would make sense to do it that way to avoid extra remotes and it would stop the factory immobiliser getting annoyed with the extra stuff. This wouldnt be a diy install. I used to fit car alarms for a company for many years. They are very compicated.
Mongoose Map77
Viper 3903TR
Cyclops 695Kit
Oh okay, so by saying that would I be able to find a evo x alarm and fit it into the lancer? If it has the canbus
- adamhumphrey
Here is a link explaining the standard alarm from the lancers/ASX/outlander
You may need to turn on google translate. It's configured through the etacs. It explains about extra sensors etc you can add.
http://mmc-autoelectric.org.ua/outlander-iii-2013my/skrytye-funktsii/184-aktivatsiya-shtatnoj-signalizatsii
Here is how to add the siren if the car doesn't have one
http://mmc-autoelectric.org.ua/outlander-iii-2013my/skrytye-funktsii/344-ustanovka-sireny-shtatnoj-okhrannoj-signalizatsii
Here is how to add the function for flashing led for security alarm
http://mmc-autoelectric.org.ua/outlander-iii-2013my/skrytye-funktsii/319-podklyuchenie-svetovogo-indikatora-shtatnoj-signalizatsii-theft-alarm-indicator
adamhumphrey wrote:Here is a link explaining the standard alarm from the lancers/ASX/outlander
So would i have to do some pre-wiring for the hood sensor? or would it just be like plug and play where i replace the latch with the one that has the sensor? and with the fuse box would i just be able to plug in c-317 cable and have it work?
And i saw about programming it, how would i do that? or would i have to leave that to a professional?
- adamhumphrey
You will need the correct cable (tactrix or mini vci) that's compatible with MMcoding and MMcoding writer software.
Software available here
https://forum.kolyandex.su/viewforum.php?f=6&sid=67763382c8a98b23610debc280d4306d
If you can't find it I can send it to you its free software. Just send me a private message with your email and I'll send you it.
The bonnet wiring is most likely there but I can't guarantee you of that. It looks like this. This is on my car an Evo X
Remove the plastic cooling panel.
The wired bonnet switch looks like this.
The plug and factory wiring for the bonnet switch
Hope that helps
Hope that helps
adamhumphrey wrote:You will need the correct cable (tactrix or mini vci) that's compatible with MMcoding and MMcoding writer software.
Hope that helps
I see the bonnet one so by saying that would the rest of the system wires by there just have to purchase the parts?
- adamhumphrey
I would think so. But I can't answer that for sure
adamhumphrey wrote:I would think so. But I can't answer that for sure
Alright, I'll look into it and with the boot alarm and door alar.? Is that also similar to the hood where I'd be able to see where the connector is?
- adamhumphrey
The car should know about door ajar. Do you get an indicator on dash if boot is open?
- adamhumphrey
Found this, could only try. I actually read people enable the horn through the etacs for the alarm.
https://www.mitsuguide.com/gimes-71-changing_the_security_alarm_settings.html
Users browsing this forum: No registered users and 120 guests
