Driver door lock
Dr No0b
Driver door lock
Postby Dr No0b » Sun Nov 15, 2020 4:17 pm
Hey guys just ran into a problem with the front door lock when i go too lock it by pressing the button on the key all 3 doors lock and unlock besides the driver side door the lock it’s self tries to unlock it self but Barely budges I took off the door panel and had a look at the cables and there’s nothing causing them too get stuck but if I manually unlock the lock by inserting the key into the lock off flicking it while inside the car it works and unlocks/locks all other doors it was working fine this morning and now going too unlock it this after noon it just didn’t work and hasn’t worked since I don’t know if it’s the heat or the actuator is fired someone please help
Re: Driver door lock
Postby bumblebee » Sun Nov 15, 2020 9:44 pm
Must be stupid hot for it too fail
I have had my lancer in temps over 45° C and zero issue with locks
Try the simple things in life , check the basics, reseat fuses , check the battery and not a volt meter either - get it tested with a proper load testing device , have a hunt thru a service manual perhaps? There are links to them on this site.
