taking off the side fenders?
redlancer08
Postby redlancer08 » Tue Oct 06, 2009 5:14 pm
Does anyone knows how to take off the side fenders.?
SIR-VRX
Postby SIR-VRX » Tue Oct 06, 2009 5:41 pm
Yes I know. What are you doing? :P
Want to know how?
1. Remove clips front wheel arch plastic.
2. Remove front bumper and headlight.
3. Remove the plastic corner but next to the side mirror mounts.
4. Remove the side indicator and unplug.
5. Between the door and fender, behind the fender is a plastic cover. Remove the clips and then you will pull the plastic around to discover a bolt. Remove it.
6. Remove the other bolts holding the fender on.
You're done.
redlancer08
Postby redlancer08 » Tue Oct 06, 2009 6:05 pm
any pics.??...any easy way?..thanks by the way
SIR-VRX
Postby SIR-VRX » Tue Oct 06, 2009 6:16 pm
You might be lucky and be able to remove just the side of the bumper out of it's clips, rather than remove it all. as for the headlight, you may be able to do away with removing it too.
This pic shows the location of the bolts.
redlancer08
Postby redlancer08 » Sat Oct 17, 2009 11:25 am
is there any place where i can get a new fenders? Due my side fender got dent on it. im comparing the price which one would be cheaper. panel bitters or a new one.
SIR-VRX
Postby SIR-VRX » Sat Oct 17, 2009 11:29 am
Depends on the size of the dent...
Panel beaters could beat it out if not too big, and bog it up if need be. Then respray. If you were to buy a new panel, you'd have to get it painted anyway. Best thing to do would be to go visit a panel shop and get a quote. They'd tell you if they could beat it out or if they would have to replace the whole thing. And they could get a panel cheaper than you could anyway.
redlancer08
Postby redlancer08 » Sat Oct 24, 2009 6:18 pm
where am i able to get a new fender? cheaper? and other body parts?
SIR-VRX
Postby SIR-VRX » Sun Oct 25, 2009 4:45 pm
http://www.ozeparts.com.au/
Their site is under construction ATM, but they have various parts and panels for the Lancers.
