Coilovers vs springs
NorcalPR
Postby NorcalPR » Fri Jul 03, 2020 6:30 pm
Ok I have come to a fork in the road I was really considering putting coilovers but don't know if what I'm looking for is worth the extra expense.. I want to lower the car but thestock handling doesn't seem bad as of now.. if I was to use lowering springs do I have to get anything extra to adjust camber or is it not necessary I have installed springs before but never coilovers if someone could respond that had installed both it would be very much appreciated
Re: Coilovers vs springs
Postby bumblebee » Fri Jul 03, 2020 9:13 pm
I suggest adjustable coil overs
Yes they are expensive
Worth every penny
Check out MCA Australia
Adjustable coil overs like MCA the advantage of having them is you can get parts to rebuild them
You can get different spring rates for them as well as replacement spring isn't too difficult to replace yourself if you wish.
Check out MCA purple.
