Thanks in advance, 2010 CJ VRX
fog lights into high beams?
Aussiesausage
hey guys. So my light bar was wired too my fog light switch ( I got no idea, just how it was ) is there away I can join my fog lights, so my light bar turns on with my high beams? So connect my foggies to my high beam circuit pretty much, is there away to do this?
- lancerdarryl
Re: fog lights into high beams?
Light bar should only come on when high beam is selected and go off when low beam is selected.The light bar should also have a separate on/off switch this allows you to turn it off when high beam is selected.
Fog lights should work independently of the headlights i.e. You turn them on and they stay on whether you have high or low beam selected.
The light bar needs its own relay and wiring to work correctly and safely.
Aussiesausage
Yeah I understand that. Who ever has done it though has the lighbar to switch on with the fog light switch though, i need to change it too the high beams.
Not much point having high beam so close to the ground
The reflection off the road will make it so you can't see and greatly increase your risk of a crash and injury to yourself and others.
I can't see this ending well.for you
More projects to come
