Regarding the 10 inch audio unit for lancer
MysteryGuy2107
Postby MysteryGuy2107 » Wed May 13, 2020 12:31 pm
:hallo:
I am actually new to this forum and its been about 10 months since I bought a 2011 lancer sx (Its my first car actually :D ). So I was scouting on youtube regarding the mods which I can do and I came across with this...
https://www.youtube.com/watch?v=QbtUX6QXXts&t=1s
https://www.amazon.com.au/s?k=sygav+lan ... nb_sb_noss
So, I started doing my research regarding this audio system and I got some questions :-
1. How do I get to know which music system I own? Some say its a rockford fosgate system but my car doesnt have that sticker to confirm that and since I dont run CD (Who does that in these days), I have no idea that do I have a 6 CD changer unit or a single CD unit.
2. Does this audio system works with the controls on the steering wheel?
3. Since this system comes with its own microphone and since my car already got bluetooth and mic to take calls, is there any way to use that same mic which is already in the car?
4. Is this thing even worth to upgrade??
I would appreciate a lot if anyone can help me out with this.
Cheers!
Re: Regarding the 10 inch audio unit for lancer
Postby bumblebee » Wed May 13, 2020 1:03 pm
The Biggest question you forget to ask is
When this unit is faulty , who repairs it?
Do I send it back to USA to be fixed?
Is there a local service agent?
What's their usual turn around time for repair?
How reliable is the unit?
My preference
Kenwood
At least it can be fixed in Australia
And if I want to sell it I can and gets a decent resale value on it
The no name brand stuff good luck getting a decent resale value on it
ronaficionado
Postby ronaficionado » Wed May 13, 2020 1:24 pm
Hi MysteryGuy,
seems you have a 6CD stacker in built on base model. Its not a Rockford Fosgate system or there would be logos on your dash.
You can control volume and song choices/stations with the steering wheel.
It also has bluetooth functionality.
Worthy of an upgrade? Absolutely! I would try and get a Mitsubishi OEM upgrade but the cost is expensive unless you have money to commit.
Or....you can upgrade with an Alpine, Clarion, Pioneer system that can fit the dash unit below;
https://www.scosche.com/2007-12-mitsubishi-lancer-din-w-pkt-dbl-din-kit
Below theres a step guide on some brave man that has done this already;
http://youtu.be/0wIIdcKImIc
https://www.youtube.com/watch?v=PVIxUqHNxW4
Make sure you get an aftermarket system with bluetooth functionality so you can use the buttons on steering wheel to take calls.
Do your homework and you will be ok.
2014 Lancer VRX - 2.4L Mivec
Process of inner & outer changes ongoing.
MysteryGuy2107
Postby MysteryGuy2107 » Wed May 13, 2020 3:29 pm
Thanks guys for your repiles but these things raise some more questions in my mind,
1. Instead of just changing the main unit, should I first change the OEM speakers to the rockford fosgate then proceed to change the main unit?
2. Is there a difference in the unit itself based on what side the driver side is at?
3. How hard is it to hook up a rear camera as well and is it possible to get the OEM styled camera or should I go for the link at the bottom?
https://www.amazon.com.au/SYGAV-Reverse ... B01JC90LT4
4. Can you suggest any other useful upgrades which I can do on my stock Lancer SX??
And Btw, what was in Mitsubishi's mind when they made this 'SX' trim in the first place?? I mean they've mixed the features and there is no information whatsoever on the net to find out what features are there in MY lancer since there is not a lot of proper information regarding the features and technical things about the SX trim.
Thanks in advance!
Postby bumblebee » Wed May 13, 2020 5:04 pm
If you want to go nuts and upgrade speaker you might be better off to upgrade the amp as well
This will start to cost some $ if.you want to do it right.
Sadly too many people spend a truck load of $ on speaker and half a semi decent header unit and put .20 cents into an amp and wonder why it sounds like crapola.
The amp is what does all the hard work and gives you decent sound
You can get away with low end speaker and still have a great sound inside the car
I have a Kenwood ddx9017dabs HU , Alpine pdx-f6 amp, and door speakers are Jaycar 6.5 inch Kevlar and front doors also have seperate one inch tweeters , 80wrms pearless I think from memory they are.
More then loud enough to go deaf with.
And for some bass a fusion 12 inch sub in the boot, self powered. Works a treat.
As for upgrade to do
There is tons to do
Depends what you want to do?
Stereo?
Suspension?
Engine performance?
These topics are covered quite compressively on this forum currently, yes the threads are old, the info is still 100% current
ronaficionado
Postby ronaficionado » Wed May 13, 2020 7:27 pm
From drive.com.au website
"OVERVIEW
The 2011 Lancer SX comes with a set of visual add-ons and enhancements for just $1000 above the price of the base model ES."
https://www.drive.com.au/car-review/2011-mitsubishi-lancer-sx-automatic-sedan-road-test-review-72989.html
Brochure:
http://australiancar.reviews/_pdfs/Mitsubishi_Lancer_CJI_Brochure_201110.pdf
Hope that clears the fog a bit....
Postby bumblebee » Wed May 13, 2020 8:14 pm
Holy thread hijack batman!
Someone who has skills to use Google and post about it batman!
I don't believe it
I must be seeing things
Awesome search skills
Search on Boolean functions for Google searching and flex your search muscles
MysteryGuy2107
Postby MysteryGuy2107 » Wed May 13, 2020 10:33 pm
ronaficionado wrote:From drive.com.au website
"OVERVIEW
Brochure:
Ronaficionado.....dude! You have no idea how much easy you just made my life by sending me the links for this, thanks a lot bro!
And speaking of upgrades, I am looking for some small, cheap and reliable upgrades in all the aspects like performance and aesthetics. I was doing some research and peeps were recommending to go for a tune by Merlin who I believe lives in Brisbane which is just almost impossible for me to go since I live in Melbourne. I also searched for some other parts like a cold intake and so on but this raises another question in my mind which I think is a bit dumb but i've seen peeps talk about it a lot and that is, how similar the internals, externals and so on are similar between a lancer X and an Evo X?
MysteryGuy2107
Postby MysteryGuy2107 » Wed May 13, 2020 10:39 pm
Oh and one last thing, is there any proper aussie mitsubishi site where I can find the any and all the OEM parts like OEM fog lights, rear camera, that rockford fosgate system and so on??
Thanks in advance
Postby bumblebee » Thu May 14, 2020 6:17 am
https://www.findapart.com.au/
Your one stop shop for a truck load of wreckers Australia wide
Buy the tactrix open port that I told you
You can do a remote tune with . Merlin via email
Very simple and easy process to do
https://www.tiperformance.com.au/produc ... -ecuflash/
4b11T and 4b11 motors are quite dissimilar internally
CAI are vastly over rated , there is only one that actually works , can't remember the name
Nothing wrong with OEM stuff, go nuts and wrap it as per photo links provided
https://i.imgur.com/tlgAcmX.jpg
The vast majority of your questions have been answered before
Spend some time reading thru this forum thru the threads , you have much to digest
ronaficionado
Postby ronaficionado » Thu May 14, 2020 10:13 am
I really need to buy gold insulating tape.....
Postby bumblebee » Thu May 14, 2020 10:36 am
And some good heat wrap
Ditch the OEM air snorkel replace with Ralliart
Get some exhaust wrap and wrap the radiator hoses also to reduce heat under the bonnet
