COMPLETE - HKS Superfire Spark Plugs Group Buy!!!!!
HKS SUPERFIRE SPARKPLUG GROUPBUY
OK Guys,
I have managed to get an awesome deal on some special sparkplugs
NEVER AGAIN WILL YOU SEE THIS PRICE
HKS SUPERFIRE RACING PLUGS
There are plugs for NA, Ralliart and EVO.
These part ninja enhanced plugs have enough spark to lite up Western Sydney after a riot
NO SPARK........ MEANS NO GO...........- PERIOD
you need spark to go.
FACT:
BIGGER THE SPARK THE BETTER THE BANG.
These normally retail for $70 per plug $280 the set
A WHOLE LOT OF BAM $179 for the set **delivered** (Australia only)
ASK ANY TUNER PLUGS ARE ONE OF THE KEY POINTS OF PERFORMANCE
I would like to get about 10 buyers.
I need to finalise orders by Sunday 27th, so we need to get cracking if you want in on this awesome deal!!
So who is in?
Purchasers
1. lzy_eye
2. Mizta_B
3. Infinite
4. Blanka
Maybe's
1. tadz0rz
2. exaltd
OK Guys,
FACT:
So who is in?
Purchasers
1. lzy_eye
2. Mizta_B
3. Infinite
4. Blanka
Maybe's
1. tadz0rz
2. exaltd
Yeah - Count me in Shane
These plugs are fantastic and will definately make a big difference
to your cars performance and reliability
Excellent price for the HKS quality
Merlinised....
Merlinised....
If they weren't doing anything else probably $50....
Honestly, it is pretty simple.... Unscrew cover, unplug coil cable, unscrew coil, remove coil, unscrew sparkplug, screw in new sparkplug, replace coil, screw coil in. Repeat another 3 times, replace cover.
If you didn't want to do it yourself, I would try and find a mechanic mate or something
- spareparts
tadz0rz wrote:Dont mean to be dragging on with my questions, but where abouts would i get a spark plug socket thing? Ive got a socket set, probs no extension long enough but i can get another one..Whats one of the spark plug sockets worth?
most socket sets will have a spark plug socket in it, if you were in sydney i no a few ppl that would be able to do it for you, my self even
the voices may not be real, but they have some pretty good ideas
:D
does the spark plug need to be set for our engine or is the spark plug pre spaced. there is a certain gauge for every engine that the spark plug need to be doesn't there. i have a spark plug gauge. its a like a keyring with heaps of thin plates at certain thickness something like .1 of a mill and so forth. for spacing for sparkplug. not to sure on it.
Its for gaping of the hook to the electrode some cars are different distances, just to help you find out.
theres some help for you.
also if people wants to know about spark plugs removal and replacement.
There is howto on spark plugs
Consult your vehicle's manual. Look up where your spark plugs are, how many you have, the correct "gap", and the size socket needed to remove them. Also write down the vehicle's make, model, and year. The gap can also be found on the emissions label under the hood.
1. Expect spark-plug work to be tedious. If this is your first time, plan 3 or 4 hours after engine cools (or 1 hour on several days), allowing 15 minutes per plug. It is harder than changing air filters, fixing flat tires, or starting a mower.
2. Consult your vehicle's manual. Look up where your spark plugs are, how many you have, the correct "gap", and the size socket needed to remove them. Also write down the vehicle's make, model, and year. The gap can also be found on the emissions label under the hood.
4. Find out (from the reference book, the packaging, or the employee) if these spark plugs need to be "gapped". Some modern plugs should not be gapped (but others can have different gaps, depending on use in either 6-cylinder or V-8 engines, etc.).
5. Park vehicle, turn off the engine, and open the engine compartment, to cool for hours. (WARNING: After running a car for a long time, the spark plugs can be the hottest part of engine! While it can require several hours to cool enough, it can require several weeks to heal burnt skin.)
6. Take (if needed) a wire-gauge spark plug gap tool and adjust the distance between the two electrodes. Between the electrodes is where a spark is made. One electrode will be an L-shaped piece of metal (hook), the other a metal prong centered directly across from it. Set the gap between the two electrodes, from .028-.060 inch, such as .035/.040 /.043 /.050, as in book (see Tips below).
7. Collect tools & new plugs (perhaps in a tool-tray). Remember which direction the socket-wrench switches to reverse/unscrew: wrench might not be visible when working back plugs.
8. Check fit of new plugs inside wrench-socket gasket. If new plugs stick to rubber gasket, consider removing gasket with screwdriver in square hole, to just use tape. Like taping screws to a screwdriver, the socket can be taped to spark plugs (not the threads) with scotch tape, for easy release once inside the engine. Otherwise, have pliers to pry the socket off new plugs once installed.
9. Locate (with the help of your manual or a repair manual for your vehicle) the distributor spark-plug cables/wires. The number of wires will be equal to the number of spark plugs your engine has. Often these wires are red or black, and will be equally divided on opposite sides of the engine.
10. Using masking tape, mark each of these wires for where they connect. Don't rely on memory: if interrupted, easy to forget, and engine can run rough with crossed plug wires. For 8 cylinders, deducing plug connections is almost impossible (120 choices for 5 wires) -- in that case you must contact an expert or study wiring guides.
11. Remove each spark-plug cable, pulling the caps (to avoid breaking cable wires). Caps should come loose by very intense twisting/pulling (avoid jerking/hitting fingers).
12. Using compressed air, pressurized engine cleaner, or a brush, clean all debris from around the plug.
13. Using a spark-plug socket, remove each plug from the engine, and replace each with a new spark plug. Don't over tighten (usually just 1/16 turn, after finger-tight).
14. Replace the spark-plug cables on the same plugs they originally came from, and remove the masking tape.
15. Remove tools near engine (beware the moving belts), close your engine compartment, and start your vehicle.
