Hi all , thinking of an upgrading turbo for my GSR.
What have you guys had and your experiences ?
New turbo on the market called intense turbos 55/56RS and heard good things about it, not sure.
Im upgrading the fuel system to support flex tune also
Evo x Turbo upgrade
Evo x Turbo upgrade
2014 Evo x GSR
K&N Typhoon CAI
Grimspeed 3 port
Nvidia N1 dual cat back
Fab test pipe & Dump
Turbosmart wastegate
Re: Evo x Turbo upgrade
What's so wonderful about he new turbo?
What upgrades to the fuel line are you doing other then a flex sensor?
More projects to come
I have seen some good numbers from these turbos online but im trying to compare to other turbos like gt pumps 712 or blouch 2.0. So i want people experiences/suggestions. Still hunting.
Not sure tbh with fuel lines, breif chat with my tuner and spoke about injectors and pump.
I told my tuner i wanted to upgrade turbo,manifold and cams and thinking about e85 afterwards but he suggested do it all at once as it turns out cheaper. But my main preference was turbo and other upgrades.
What do you suggest ?
2014 Evo x GSR
K&N Typhoon CAI
Grimspeed 3 port
Do what you can afford. If you have to do it in steps then do so. It's nice to have a ton of HP and a rocketship of a car, however the road speed limit still apply to us all.
If you go E85 the wiring to the pump will also need to be upgraded. The OEM wiring harness will let you down. You won't be able to get enough current/amp thru the wiring.
Have a chat to Merlin.Tuning@gmail.com and pick his brain
Ok thanks mate, i agree and i do abide by speed limits. When i bought an evo i had a power figure in mind and knew what kind of power i wanted.
Ill send him an email.
2014 Evo x GSR
K&N Typhoon CAI
Grimspeed 3 port
GTP712 probably the best turbo to run with an 18 or 22 psi Turbosmart actuator and ID1300 injectors with AEM300 fuel pump.
Thanks Merlin , yeah i spoke to mark from gt pumps yesterday and 712 is going to be my choice. How about cams any suggestions ?
2014 Evo x GSR
K&N Typhoon CAI
Grimspeed 3 port
