Lancer Bulb List!
Ronan.Butler11
Re: Lancer Bulb List!
Postby Ronan.Butler11 » Thu Feb 16, 2017 6:58 pm
Quick question guys, a mate got some LED globes for his Subie the other day for $40, anyone know if the LED's are compatible in the '09 lancers?
If so you guys got any idea what ones to go for?
***Edit***
i'm not entirely sure if finding some of the headlight spec. led bulb would be a match, thought i would ask first
'09 Lancer VRX
Modifications:
18" King Rims
Ralliart Snorkel
Re:
Postby bumblebee » Sun Jul 16, 2017 9:14 pm
Lancer1993 wrote:
Anyone tried fitting a 4x4 style light bar to their CJ?
I have one of these. 15inch about 240 watt mounted to a licence plate bracket and works a treat
Postby bumblebee » Mon Oct 02, 2017 2:23 pm
BCF currently is doing amazing run out deals on LED bars
Their 20 inch bar is down from about $300 to just $110 and is Amazingly bright. They have two styles.there is a spot light bar and there is a combo bar that has both spot and flood in the same bar. They also come with a 3 yr warranty. Attached to the front with a bracket that bolts to the back of the licence plate.works a treat
The 20 inch bar looks great on the front of the lancer
The 30 inch is a bit big they are $158 at BCF
Slightly overkill on the lancer but if that's all the shop has then grab it you wont be disappointed
For a plug n play wiring kit get one from "Stedi" in Melbourne. Keep your eyes on them in ebay.you can get them on special delivered for about $40 or less
Azza_07
Postby Azza_07 » Tue May 22, 2018 9:01 pm
ZERO COOL wrote:Front of car:
Front turn signal light: 21watts bulb: WY21W
Head light, high beam: 60watts bulb: 9005 HB3
Head light, low beam: (halogen bulb) 51watts bulb: 9006 HB4
front foglight: 55watts bulb: H11
Front side marker and parking light: 5watts bulb: WY5W 194
Side turn signal light: 5watts bulb: W5W 195
REAR of car:
High mounted stop light: ---watts bulb: -----
License plate: 5watts bulb: W5W 194
back up light: 21watts bulb: 7440
tail light: 5watts bulb: W5W 194
tail and stop light: 21/5watts bulb 7443
rear turn signal: 21watts bulb: 7440
rear sidemarker: 5watts bulb: W5W 194
Are these the same for the CF models?
Quismiff
Postby Quismiff » Wed May 23, 2018 9:19 am
Apart from the 5w park light they should be, as the DRLs in the bumper serve as the parkers to satisfy ADR rules, you'll notice they dim when the headlights come on.
2007 MY08 VR-X (cj-red)
Azza_07
Postby Azza_07 » Wed May 23, 2018 1:17 pm
Quismiff wrote:Apart from the 5w park light they should be, as the DRLs in the bumper serve as the parkers to satisfy ADR rules, you'll notice they dim when the headlights come on.
cool thanks, thats what i thought, thinking of buying some new 4k+globes high and low.
Return to “Lighting”
